- Sep 19, 2001
DLC is a porous coating, which is why it doesn't prevent rust. But, it will also hang onto oil, so it helps slightly there.
Edge geometry has a bigger impact on overall cutting performance, but you can always alter the edge geometry on a knife while you can't change the steel. Badly ground M390 will lose to 440C, but then you just need to resharpen the M390 and it will come ahead in edge life. You can't do anything to the 440C to catch back up at that point. Steel is the most important thing because that is your starting point. Heat treats and grinds can be redone, but you aren't mixing in or taking out alloying components once the barstock leaves the mill.
