harrymole,
You make alot of sense and don't be surprised if a particle metallurgy version of D2 makes its way to the market. The CPM process has its limitations and surprisingly enough it is limited in the direction of lower alloyed steels and tool steels. To the best of my knowledge there never has been a CPM S7 produced and this will never happen. ESR S7 has been made but not CPM S7.
We discussed CPM 154 for years and decided to introduce it because the custom knifemakers wanted a more user friendly, premium quality, stainless knife blade steel. One that was easier to grind and easier to finish than CPMS30V. We try to listen to our customers and that is why we introduced CPM154. This grade is for the custom knife makers and if the production companies want to use it - great.
Two things we learned about CPM154 - it will achieve a higher hardness than conventional 154CM when using the very same heat treat procedure and it is tougher than conventional 154CM - approx 2X the toughness.
We can do extensive testing and publish the data but until the steel is used, tested, and endorsed by custom knife makers, production knife companies and end users - all the data we provide doesn't have much merit.
Thanks for listening.
T.Scott Devanna
T.Scott Devanna
