A gun beats a knife every day for SD. A folder is pretty useless for SD. I can do more damage with a solid boot than with a knife.
Do some research, or better yet, actually test this out yourself. A pocket knife is not enough blade to pose a threat of much more than flesh wounds. If the attacker was deterred by a small blade then moderate hand to hand training would have also worked. If you are going to attack someone, you will have either a large knife (kitchen knife or otherwise large) or a gun. A knife will do nothing against a gun unless you are within arms reach.
If you can't get to a fixed blade "fast enough", what makes you think you'll have time to pull out a folder, flick it open, and then get a good grip before using?
Yep, extenuating circumstances and all. Thank you for clarifying. See what I mean by people parroting what others say? My suggestion is to go folder with a non lethal primary like a tazer, if you think that fixed blade will be trapped because of your type of clothing. Folders, stun guns, pepper spray, kubotans, and batons/blackjacks are all relatively small, lightweight items that you can carry every day. In combination if you choose. Stun guns and spray especially will both buy you plenty of time to run, counterattack. ..whatever you plan on doing. Anyway to answer your original question, the CQC7 is made for rapid deployment and has a single bevel so you can sharpen it quickly, but is just so so as a utility knife. The ZT is going to deploy fast too, but you're going to have to change your grip as it deploys. Bear in mind that the ZT has better steel and is a bit bigger/more aggressive.I've seen this comment a lot. I appreciate "practical" advise, but sometimes I think posters here need to see where the person asking the question is located (assuming location is listed) for responding. I'm not from the US. I don't have to worry about a gun over here. Except for vacations there, the odds of me ever coming face to face with a civilian who owns a gun are next to none.
Flesh wounds will sufficiently even the odds for me to escape a fight against someone who outweighs me and has greater reach. If the guy has to limp after me, I can escape. If the guy is bleeding out, I can escape.
Not about being unable to get a fixed blade out fast enough, but rather being in a position where I can't reach my fixed blade to begin with; e.g., being tackled against a wall.
Furthermore, I'm an Orthodox Jew and I'm often wearing clothing -- somewhat resembling an overcoat -- where it's not possible to wear a fixed blade outside. That's what the folder is for.
Oddly enough, it's cheaper.Bear in mind that the ZT has better steel and is a bit bigger/more aggressive.
For what purpose?
Rev, did you see your post count? 19,999, one more for 20k !!!!![]()
Get the Emerson. Trust me.
And never sell it. Trust me.
