I've seen the pics you post here and on JD
You don't have to show the world everything you make, just the pieces that turned out perfectly.
I mean that -- perfectly.
Look at good makers pics and yours, see the differences and make changes
- for instance that kydex sheath on JD flame burned and stapled together...I just shook my head...
My junk draw is full of crap, but
no one will ever see it.
If you want to be taken seriously, ditch the FTW engraving and booze in the pics
Forget dagger grinds, try just one sided chisel grinds for a while.
Symmetry is key.
Have a plan ahead of time - Scribe in lines on the steel on the edge and side - so you know where to go and where to stop.
To get the best out of your grinder:
-Use a jig,
-Start with a super fine grit like 400 or 600. The fine grit will slow down the metal removal and mistakes happen more slowly.
Never stop in one place, always keep it moving.
The knife does not have to all be done on the grinder.
You can flatten out your grinds by hand sanding.
Check out Don Fogg style sanding sticks, or the huge WIP thread by Nick Wheeler
http://www.bladeforums.com/forums/s...Wheeler-s-Steel-*-Stuck-in-the-metal-with-you
Use barstock instead of files, it's softer to work with then send it out for pro heat treat.
Pick a small utility and make 20 of them, all the same, each one better than the last.
I like the "CIA Zipper Pull" - just try to refine it
Thin cuts better
Aim for perfection, not production
Try this info too.
http://www.bladeforums.com/forums/showthread.php/864687-Knife-Making?p=9793335#post9793335
