I guess I can say that I've seen worse, if that makes you feel better.
There's definitely some potential there, and I can see what you were probably trying to do.
My advice:
Stay away from jigs. They'll hurt more then they'll help.
Use SHARP belts. You'll never have a chance of getting an even grind once the belt starts to dull. Use dull belts for rough profiling, and after that, throw them away.
Use quality steel. A poorly annealed file isn't going to grind as well or as evenly as a properly annealed piece of quality knife steel.
Start with a flat grind with clean lines and THEN move onto convexing. That, or ditch the convexing altogether. For small knives like you are making, there's really no reason for it. It actually makes them cut less efficiently, IMO.
Make sure you're starting with straight steel, and if you're using a flat platen, make sure it's actually flat. ANY deviation, blemish, divot, etc... will transfer to your grinds. If you can install a ceramic liner on it, that's all the better.
Grind with consistent pressures and angles, and with deliberate actions. Any minor angle or pressure changes will show up magnified in your grind lines.
