Question to the kwackster: Was there any damage or impact to the titanium? I suspect the stainless pivot hardware was affected similarly to the blade.
There wasn't any damage to the titanium handles or the steel pivot.
A couple questions I have:
What lube were you using?
Were you running the pivot very loose....IE with a bit of a gap between the blade and washers?
This is really the first I've ever seen of any serious corrosion issues after a few years on this forum.
The lube i used on this Sebenza was 85 weight Nano-Oil on the washers and a few tiny drops of 10 weight Nano-Oil between pivot & blade.
This provides the user with a little easier "hydraulic" opening & closing action compared to CRK grease and also lasts a long time.
I always set the pivot tight enough so there isn't even a hint of blade play, yet the blade falls closed on it's own once the lockbar is held aside with my thumb.
What may have happened is that the citric acid in the oranges over time first slowly dissolved all or most of the oils and then proceeded to act as an electrolyte between the washers and the blade, thus slowly etching those black pits into the steel.
This was suggested by a member on the German forum, and i think he could be on to something.
Maybe the holes in the washers played a role too by holding the citric acid longer than closed washers would have done, but that is just me speculating.
BTW: just before disassembling & cleaning the knife still opened & closed comparable to one that has dried CRK grease in it's pivot.
Miso,
I'm no expert, but that's an accurate description of the process. Smith and Wesson for many years "passivated" their stainless handguns. The surface had a milky finish and was more resistant to corrosion. They used nitric or citric acid.
While it's certainly possible the citric acid removed some of the chromium, the stainless stock beneath is fairly resistant to rust or corrosion. S35VN is about three times as resistant to corrosion as 440C.
I don't think CRK would recommend the grease without sound reasoning.
Stainless typically means resistance to oxidation, but doesn't necessarily mean it can't oxidize. Many stainless steels have varying degrees of resistance to oxidation with the highest resistance to oxidation going to 17-4 IIRC.. Nasty stuff..I hate machining it, but then again..it's not the worst material to machine.
I know that you are aware of this, otherwise, we wouldn't be discussing corrosion resistance. The reason I brought up passivation is because that is essentially what is happening with fruits like Oranges, lemons and limes as well as a host of others.
Here is a snippet of an article- Ironically, it's from a machining publication that I subscribe to.
"Laboratory tests have indicated that citric acid passivation procedures were more prone to flash attack than nitric acid procedures. Factors causing this attack included excessive bath temperature, excessive immersion time and bath contamination. Citric acid products containing corrosion inhibitors and other additives (such as wetting agents) are commercially available products that reportedly reduce sensitivity to flash attack."
Source;
http://www.mmsonline.com/articles/how-to-passivate-stainless-steel-parts
Now, passivation is a solute of lower concentration of citric acid..Likely, the fruits concentrate in Lemons and Limes, higher than Oranges..is added over time and repeated without proper maintenance doesn't help.
I do remember that Chris specifically named acidic fruits needing more vigilance..but I will have to contact Tim and Anne for this information.
Interesting article, thanks!
All stainless materials will corrode at some point, about all they do is slow down the processThe CRK FAQ's (as linked in an earlier post) recommend more frequent cleaning when used for acidic fruits, et al.
17-4 PH can be gummy, according to my machinists friends. I imagine it becomes easier if it's hardened. Machining is still an art, CNC or not.
this isn't rocket science.... this is common sense.... if you subject your knife to an acidic or otherwise corrosive substance you should take a minute or so and wash it clean .... the fluorinated PFPE grease will help prevent corrosion as well
the below statement taken from CRK FAQs
"It's good to clean your knife from time to time and make sure there is no built up of dirt around the pivot and lock area. If you use the knife around a particularly corrosive substance - acid food (oranges, tomatoes, etc), blood, salt water, be sure to wash it off in fresh water and lubricate the pivot.
We recommend using our specially formulated Fluorinated Grease or a high quality gun oil to lubricate the pivot - you should only need a drop or two."
