I have a CE CRKT M-16Z that I keep in the tool box at work. It used to be my work EDC but now it is just a back-up. I have nice BM 921 Switchback that I normally carry. Sometimes I forget it or something and that is when I use the M-16 again.
It has the Lawks system. The liner has been known to fail when not using the LAWKS so I use it when I need to put any pressure on the lock. I was cutting wire ties like I do everyday. It is a simple process of slipping the blade under the tie and levering the blade so you are using the resistance of the tie to help cut. It does put all the pressure on the lock but it is not abuse and it is not a lot of pressure.
Anyway, I tried to cut one of the tie wraps and the blade folded on me. Luckly I was wearing my gloves so I was not hurt. Also, I guess I never really trusted this knife so I wouldn't use it in a way that could get me hurt. I was surprised to see the LAWKS system fail as it seems like a fool proof system. It is not. THe little tab from the LAWKS got wedged between the liner and the other side of the frame when the liver bent and slipped past it.
Anyway, I looked up CRKT policy and they say that it is a life time warrenty. I sent it off to them just to see what they would do. This is the second CKRT that I have had to send back to the factory. I have only owned about 6-7 of them and two had to be returned. The other one was a Pointgaurd Minor that just fell apart in my pocket because the screws came loose. I got the replacement and traded it at a gun show towards a new BM 885.
