- Jul 6, 2005
even if you are looking for a small knife, i would still seriously consider the M21-02. aside from the more useful blade shape it also just looks and feels like a better knife.
same aluminum handle as the M16, however the blade is double ground as opposed to chisel-ground, and satin finish as opposed to bead-blasted rust-magnet finish (although this is not an issue if you get the coated blades). you can also easily find them in plain edge, as opposed to the M16s which are lately only available in plain edge in the EDC compact versions. chisel-ground is also kindof annoying to cut with and sharpen (for me, anyway), so i immediately put a proper double ground edge on my M16 spearpoints when i got them.
M21-02
closed length: 4.25"
blade length: 3.12"
cutting edge: 3.00"
thickness: 0.12"
steel: AUS-8
so its the same size as the smaller M16s, and only 1/4" larger than the EDCs but a lot more substantial looking with a thicker/wider blade.
M16-01 compact EDK
closed length: 4.00"
blade Length: 3.00"
thickness: 0.08"
steel: AUS-8
M16-03
closed length: 4.75"
blade length: 3.5"
thickness: 0.1"
steel: AUS-8, or AUS-6/AUS-4 on zytel models
as for your question re: sharpness, some of mine arrived razor sharp out of the box. other CRKT knives ive ordered arrived kindof dull. i dont think that with production manufacturers its a safe bet to assume that just because one knife arrives razor sharp that all of them will - i seem to notice in these forums that its hit and miss (heh, some people receive knives without an edge entirely). you should not let factory edge influence your decisions much since the factory edge doesnt last long and youre going to have to resharpen it anyway.
cheers,
-gabriel
M21-02
blade length: 3.12"
cutting edge: 3.00"
thickness: 0.12"
steel: AUS-8
M16-01 compact EDK
blade Length: 3.00"
thickness: 0.08"
steel: AUS-8
M16-03
blade length: 3.5"
thickness: 0.1"
cheers,
-gabriel
