Cliff Stamp
BANNED
- Oct 5, 1998
The CRKT Point Guard has a drop point blade stock ground from AISI 420 stainless steel. It weighs 120 g, with a blade 3.125" long, the OAL is 4.75" when closed, the handle is a massive 0.5" thick with 420J2 double stainless steel liners, a 6061 T6 hard anodized aluminum back spacer and Zytel scales. The knife has a liner lock with LAWKS safety latch and a ball detent and opens with use of a thumb disk.
The knife is very comfortable in hand, with one of the most comfortable clips ever felt, it curves gracefully with no squarish points to cause excess discomfort. The very aggressive cutouts across the lock and at the top of the handle are very secure but high in discomfort, they are not optomized for extended cutting but rather brief periods where high security is desired.
The blade has a high flat grind and the edge is 0.020-0.030" thick ground at 20 +/- 2 degrees. The initial sharpness was average, little shaving ability but could scrape some hair, on light thread it scored 159 +/- 11 g, well under optimal. On 3/8" hemp it took 55 +/- 2 lbs on a push, no aggression on a draw. For comparison the Spyderco Manix was initially 90 +/- 14 on thread and could slice the hemp with 15 +/- 1 lbs, took 7-9 lbs on a two inch draw offering a much higher level of sharpness and cutting ability.
The Point Guard will be used for some edge comparisons against a few standard blades, VG-10 and possibly S30V after being used for awhile as just an EDC blade. The edge will likely be profiled before the cutting comparisons because the edge as now is too obtuse for ease of sharpening on the Sharpmaker and the comparison blades have much more acute angles.
In regards to the lock, the liner is secure under white knuckling and spine whaks and light torques, with the LAWKS safetly catch engaged it looks to be near impossible to disengage the lock without applying enough force to simply break the lock apart. However it looks like the LAWKS system could be prone to disengagement on heavy stabs or cutting through loose material.
-Cliff
-Cliff
