Received the Provoke sheath today.
It is very well made. It looks better than what I've seen of the sheath that comes w/the Chinese knockoff and I assume the Provoke is better than the Chinese knockoff of the knife too.
In any event the CRKT sheath comes w/2 DOT clips: 1) thin 3 hole and 2) the standard wide 9 hole.
I tried using the thin clip vertically 1st but it was not thick enough to keep the sheath vertical; it would lean over at an angle whenever I removed the knife from the sheath. So, that failed. It is also impossible to install the sheath horizontally w/the thin clip; not enough mounting holes available. Bottom line, the thin clip is pretty useless and it been better if left it out and reduced the price of the sheath to $30 instead.
Next, I tried installing the sheath horizontally using the wide clip but the sheath/knife stuck out too far from my body and would slide along the belt until it hit a loop before I could remove the knife. So, that configuration failed for me too.
Lastly, I installed the sheath vertically using the wide sheath in the standard configuration and that worked best for me. I could push the sheath back along my body so that then knife/sheath is less noticeable but still accessible. However, I could also slide it forward along the belt for easier access. The sheath holds the knife very securely and the only way you can remove the knife from the sheath w/o it moving side-to-side along your belt is to mount it vertically.
So, I think this is the best method of attachment and the only pics I took of the sheath were in this configuration. It's a very nice set up and, even though I could just carry the Provoke in my pocket, my preferred method of carrying it will be in the sheath.
I'm glad that I bought it.
And, finally, here's a pic of the knife/sheath along w/all of the other gear that I normally carry in my urban self-defense kit. It fits right in. LOL!
Having to carry it in a sheath negates the advantages of it being a folder.
How's that?
However, whether you choose to use a sheath or not has nothing to do w/it being a folder. It's simply an alternative way to carry it.
Yes & No in my opinion.
To me the advantage of carrying a Karambit Folder is being able to carry it clipped in a pocket. If I need to carry it in a sheath, why not go with a Fixed Blade Karambit at that point? It's ready to use the moment I draw it out, no moving parts to go wrong, and faster to deploy if it's a SD scenario. Only drawback is it is bigger in profile & more difficult to conceal.
Just my opinion, and I respect yours that you disagree. Just wanted to further clarify what I meant by my above post.
The Provoke is a obviously much larger and heavier weapon that will never replace any of these other karambits in terms of speed of deployment and concealability but it is ideal where a larger knife for heavier duty is needed and when maximum concealability is not essential.
Heavier duty? In a karambit? For what? Killing people with thicker skin?
