Crocodile Dundee Knives....Would You Pack and Use One?
[video]https://youtu.be/BNFxcD60Uo8[/video]
There is another one,,,,, very similar to the Hellfire Forge version, nearly identical, but I may be wrong, it seem to be posted directly by its maker, youtube account holder who upload it
[video]https://youtu.be/H5LqfYpSvXM[/video]
DUK The Outback Bowie,,,,, this dude have awesome video on it, quite extensive, worth to see.
This guy just NAILED IT, -!!!!
The best review of youtube on Down Under Outback Bowie - worth to see from start to the end
[video]https://youtu.be/5K0S7gOj5PE[/video]
All the thumbs up
All the thumbs up
I do like the bone bauble trinkets on the sharpening rod. Knife needs more jimping.
not a chance. theyre made oof 440c which can be good just not for a knife of this size. anything over a 5" blade id want something like 1095 or 01 tool steel. id recommend a TOPS (most will do the job except for the shitty harpoon things) or a cold steel laredo bowie.
What suddenly happens with 440C knives with blades over 5"?
Based on what I see online, most the big quality knives I see broken are usually in Carbon steel: The few broken stainless ones are always extra low-cost stuff (typically Chinese)... Several broken Carbon Trailmasters and Recon Scout can be found, but I've never seen a broken stainless one (Stainless Trailmasters are not all San Mai III: Many older one are in Aus-8, a close 440B equivalent).
If DUK is known as shady, then I would agree their stainless is not to be trusted (that they don't give specs on their steel is highly dubious): Cheap stainless is often hard and displays a deceptive very good edge holding, but it is often poorly tempered, so it is prone to shock fractures.
The Youtuber whose 8 mm threaded tang broke off at the buttcap, with no batoning, just chopping, is indicative of poor tempering: Chopping on any kind of wood is by itself a very mild test, and should never induce a failure, because the knife is free to vibrate: Batoning can induce failures because it "traps" the blade between two pieces and prevents the metal from vibrating freely...
Such a threaded tang should be annealed to be softer, yet much harder than brass, and a correctly made tang should have failed gradually by showing some mild loosening from the brass threading becoming loose inside the brass, NOT an abrupt fracture of the actual steel like that...
Both the design and the materials appear at fault for the buttcap failure on the outback. The only "abuse" that would excuse this failure in my opinion is throwing... Even batoning can cause blade failures, because it is the blade that is trapped, but it should not cause handle failures, unless you hit the handle itself.
Gaston
[video]http://m.youtube.com/watch?v=buqRjxT3imc[/video]
One beautiful video, I think it seem like a Hellfire Forge version of Crocodile Dundee knife!!!! Amazing piece of steel
All the thumbs up
So what is your experience with Down under knives. Do you own one? Can you post your own pictures/videos? You love them so much, why not show us your own DUK toughness!
Seriousbladeno1,
Thanks for the Hellfire Forge videos. Really enjoyed them. His Dundee Bowie is awesome - 15 hours to braid just the handle. Incredible!
Seriousbladeno1,
TAH,,,, I only recently found these videos, also I am not too sure if they are made by Hellfire Forge, but they do seem nearly 100% identical to their models, seem like they made a good number of variations (when it comes to handle shapes and materials, or sheaths) ,,, last time I tried to visit their website was still under reconstruction.
Design of Croc Dundee large Bowie is surely still out there, influencing few knifemakers or manufacturers and is having its fans...
Design of Croc Dundee large Bowie is surely still out there, influencing few knifemakers or manufacturers and is having its fans..."
Yeah, I suck at web design, so its been sitting there forever. I made all of them. Most of the variants were either older knives I was trying to figure out the braiding pattern and knife shape, customers wanting their own spin on one or a less expensive version without the kangaroo and crocodile hide. If anyone has questions, Im always happy to try and answer them. There is a facebook link on my webpage that takes you to my Hellfire Forge FB page until I get off my ass and finish my website.
Yeah, both of the videos you posted are mine. Im the owner and bladesmith of Hellfire Forge.
Thanks for your replies, Earl. Your knives are just fantastic. You are a true artist! :thumbup:
Oh man thanks for reply! It's great to know you are here too!!!!!!! Fantastic looking knives made by you! I do not have fb page, but what are the dimensions of these Croc Bowies you are making? Can you tell something about them please? Steel, materials, you are using on these? ???? Are they forged or made by stock removal method?
Also sheaths - what sort of materials you are using, is that the genuine Croc skin too?
Great to know you are here and that we can get in touch with you also this way!!!
Sure, no problem. I looked up the dimensions on an auction they had for one of the aluminum props and blew up a photo of the actual knife to those specs to take my measurements off of. The overall length is 16.5 inches and the blade is 10.5. I forge the blade and tang to shape from 1/4" thick 2" wide 1075 and then hollow grind the edges and grind in the fuller freehand on my KMG grinder. The fittings are square blocks of brass I freehand to shape on the grinder, then polish. It took me around 2 years and 16 attempts to start getting it right. I had blurry screen caps and vague info on how everything was constructed so I spent hours going over screen caps and I bought every out of print magazine that had an article about the knife in it. I knew the handle was braided, but had no idea what braids were used, so I bought several books on braiding leather and started trying them all til I hit on the right ones. Then the bluray came out and I was finally able to verify I had the correct braids. I use kangaroo for the braiding on the handle, sharpening steel lanyard and the border stitching on the sheath. The sheath is veg tanned leather and real crocodile which is insanely expensive so I dont do too many of the full replicas. Ive done several without the braids and a plain leather sheath, and a few people wanted custom alterations like antler for the handle etc. The sharpening steel is a real butchers steel with the handle removed. I anneal the end, drill a hole for the kangaroo lace lanyard and put snake vertebrae danglers on the end like the original.
Oh, also if anyone has any specific questions feel free to ask. Im also on facebook under Hellfire Forge so feel free to hit me up on messenger.
Many thanks Sir for your reply! Your knives seem to me the most accurate custom Dundee Bowie version out there! Did you ever had an idea to make also giant Dundee Bowie folder- similar to one used in "anaconda killing" scene in 3Rd part? What other steels you could recommend and be confident to make this large Bowie from? How about 5160 or stainless?
