America has reached 250 years, and I am grateful to be here, in the best country in the world. Thank every one of you who helps make this country a better place, those who have gone before and risked it all, and those who've paid the ultimate price to make the United States what we are today.
I always thought get it hot and dunk was just not good enough,
The point of this steel was lost when Crucible failed to properly release it. They had bigger issues to contend with, one could say... Dan Farr was the driving force behind this steel. It was his desire to create a steel that would offer improvements in wear resistance that could also be readily forged. To my knowledge, it was the first forging steel designed from the ground up for cutlery applications. Many bladesmiths were and are still working with minimal equipment and 'uncontrolled' heat sources. The premise of the 'get it hot and dunk it' idea was that this steel would offer dramatic improvements over what most guys were using, without the demand of rigid temperature controls or special quenchants. In fact, Dan demonstrated HOW this was done in most forges in front of the PhD metallurgists that were developing the alloy with him by bringing his equipment to their facility in Syracuse and making a few blades from start to finish.
Can you improve on the performance through better control and process? Sure. The difference, though, is that this alloy offered dramatic improvements to what was previously available and still allowed the 'by eye' guys a better option.
I know where you're coming from, Warren, but I wanted to add this for the record. It was very important to Dan.
The second graph uses an austenitizing temperature of 1500°F.Larrin, it looks like the second graph is using the "old reliable"1500/400F recipe MOL. Is that correct?
I don't believe the numbers reported in the data sheet included a cryo treatment. That would be the easiest way to explain higher hardness here.That is interesting not only because that is the "default" recipe for some of us, but also in that you seem be getting hardness levels slightly higher than what the "factory numbers" tell you to expect. That might explain some of the difficulty in hand sanding above and beyond the mere fact that the steel has a fair bit of vanadium.![]()
I can't say what the effect of different quenchants would be at this point. For reducing retained austenite you want to get as cold as you can, dry ice is better than room temperature. You will likely eliminate most of the retained austenite with dry ice.Hmmmm. Do you think you would get any additional benefit from also using say the high temp salt and medium-fast oil hardening process like some are doing with 52100? Also, do you think that a "cold" treatment using the dry ice slurry method would be sufficient for this steel?
