Very different steels with very different purposes
both are great... the one that will be greater will depend on what you use your knife for![]()
Very different purposes? That seems a bit of a stretch in a pocket knife of the same pattern.
I agree that the steels have some different properties and characteristics, but in the end, it's a pocketknife. One may have the edge last a little longer, one may oxidize less, one may be a bit tougher...imho, of course.
I'm willing to be convinced otherwise, however...
None of what you posted in your overly lengthy reply constitutes "very different" usage. For an alleged autodidact, I'm disappointed.
Just because things dont make sense to you does not mean that things dont make sense.
It's not that they don't make sense...it's that you are a dilettante posing as an expert. And most of what you provide via the expertise you claim is regurgitated from other sources posting the information previously.
You seem to be the one person that I just can't seem to forgive this in. Perhaps some day. I admit I probably shouldn't care.
The issue was over with hours ago... leave it alone.All over a a steel ffs grow up boys
I am on the same boat.Well they're both steel, both hard, both will rust, both have the same stiffness, both can be sharpened. In terms of specifications there is a lot of difference. In terms of use we know from the various cutting tests that people have done, the Rex may cut twice as much as the cru before dulling. Material properties would say that cruware should be harder to break but will that help in real use? I am pretty cautious with my folders because I know that I can reach a point where the blade can break without warning. I don't know where that point is so I stay pretty far from it. So for all I know either one has the strength that I need. I would like to have Rex45 for use in my workshop but haven't found one I can afford yet. I currently use M4 which I think is very close. Or I might just use Cruware instead.
I usually favor hardness over toughness too
I think for most of us a longer edge retention makes more sense
Unless you want to abuse your knife you will not really need more toughness or a steel easier to sharpen
I have lots of REX-45 already and my first Cruwear arrived today and is waiting for me at home.
I really want to know about the differences in edge stability and fine edge holding.
what did you end up finding in regards to fine edge holding and edge stability between cruwear and Rex 45?
thanks for sharing If you decide to![]()
