Alpha Knife Supply
Always Innovating
- Oct 14, 1998
Based on what testing?but if the application needed a tougher Powdered stainless it would not be Elmax.
What testing is the basis for your opinion?
Chuck
Knife A & knife B, each chops a nail.
Knife A resulted with a 3 mm dent.
Knife B resulted with a 2 mm chip.
Which one is tougher?
For me - B is tougher because it has less damaged. Otoh in knife world, the answer might be 50/50 because pliable/ductile often marketed as tough. However, if knife B has a crack longer than 3mm or broke in half - Knife A is tougher.
Chuck
The degree of damage depth from cutting hard stuff like nail is not directly refer to toughness. Its combination of hardness(strength), toughness and the matrix construction of the material. Otherwise by your logic tungsten carbide would be considered to be tougher than copper which in reality it is not.
Toughness is resistance to breakage via stress or impact. If we want to make a appropriately comparison in toughness among steel we need comparable in hardness and properly grain structure. People can have a knife made of steel like L6 or 5160 at 57HRC and still being very brittle due to the lack of proper normalizing cycle after forging.
Totally agree in every wayElmax is the most versatile super stainless steel period.
It is the toughest steel of all powdered stainless with excellent wear resistance. I would even preferred Elmax over M390 or S90V.
XHP is one of the best overall performance stainless steel but Elmax is just slightly better.
I kind of disagree. Toughness is resistance to breaking, cracking or chipping, whether from impact or pressure. Strength is resistance to rolling or bending (beyond the yield point). Strength is highly correlated to hardness.
Edge stability is a blend of toughness, strength and wear resistance.
Given the same impact on the same or identical nails with identical edge geometries for A and B, A is tougher because the failure mode is deformation. The failure mode for B is fracture.
Going into a ring to duke out with a robot. Fighter A came out with 3 teeth missing, while fighter B came out with 2 teeth missing. Which fighter is tougher![]()
are you serious about toughest steel?Id argue that CPM 154 is the toughest of the Powdered Stainless, but that Elmax has more edge holding
"Toughest PM Stainless"are you serious about toughest steel?
Number of high end kitchen knife makers used to use CPM 154 until many in that "industry" switched over to higher hardness AEB-L.
PM AEB-L is pointless.With the resurgence in popularity of AEB-L as knifemakers have developed high-hardness heat treats for it and been able to get it in thicker stock, I wonder if we'll see Crucible do a PM AEB-L. Bet that'd be a real sweet option for people wanting stainless fixed blades without compromising on toughness as much.
Larrin has established a theory framework for explaining toughness and it's correlation with carbide size and volume. That theory worked great on many steel types that he tested so I tend to believe in it. According to the micrograph of Elmax, it looks quite similar to XHP, so even though Larrin didn't test Elmax's toughness, I would expect Elmax's toughness to be similar to XHP, and may not be better than CPM-154. However, I am yet to see Larrin's test on it to make the argument.
For comparison of XHP and Elmax, I will definitely pick Elmax. Data from different sources have suggested that edge retention of Elmax and XHP are at similar level, while Elmax is much more corrosion resistant than XHP. I would expect Elmax to be similar to S30v/S35vn on both edge retention and corrosion resistance.
Currently for stainless steels, the toughness and edge retention seem to contradict with each other, if Elmax is really tougher than CPM-154, then that is great news as that means the boundary of edge retention/toughness line has been push further for stainless steels.
