That's funny.Assuming you mean CTS-XHP, it holds an edge very well in my experience. It all depends on heat treat, edge geometry, and what you are cutting, but I consider it on a par with M4, M2, M390, etc...
That has to do with the sweeping grind. It creates that flat spot.
Update to this:
I have used the Ultimate hunter on and off for some time now, light processing of some poultry and some meats. I did not like the thick grind. Rather than copy what REK I decided to do a hollow grind.
Average thickness behind the edge is 0.25mm with 0.5mm (0.0020 inch) about a centimeter up from the edge. I did a full mirror to see how it feels on the belts, then went back to 60 grit with a light 800 grit over the 60 grit to smooth it out a bit.
CTS-XHP is still far more similar to RWL-34 than I anticipated, polishes, grinds the same way on the belts. RWL-34 for me is the bees knees of balance between properties so this has been a pleasant surprise.
The lock has settled in deeper than when I received it.
That's funny.
I can't find the humor.
I'll let the guy I replied to explain it.Agreed. Totally unproductive when someone says something like "that's funny" without explaining why, how, or providing any information at all to support their position.
I'm guessing that he thought it was funny that I said hxp instead of xhp , heheI'll let the guy I replied to explain it.
ahaa , that seems to be a more likely scenerioI'm guessing it's because he put XHP in the same category as M4,M2 and M390. Don't get me wrong XHP is an awesome blade steel and I have/carry a few but it doesn't hold a candle to those steels listed in most areas.
A cookie for you, Sir.I'm guessing it's because he put XHP in the same category as M4,M2 and M390. Don't get me wrong XHP is an awesome blade steel and I have/carry a few but it doesn't hold a candle to those steels listed in most areas.
