Ankerson
Knife and Computer Geek
- Nov 2, 2002
The human element and variables is exactly what a knife needs to be tested for. Yes the test tells you what a steel will do at a hardness but it doesn't throw in random staples into the cardboard being rammed into at full force. It don't tell you what happens when a box full of something metal right under the cardboard will do. When you get that inevitable swipe into the concrete. When you have flaps glued down so hard you need to pry it apart. Them are the things tests will not tell you. Ask anyone who has worked around any amount of cardboard. All of them will tell you about multiple staple hits in a day, concrete accidentally contacted, fiberglass reinforced tape, hard metal object in a box the tip will contact. Exactly everything you need a cardboard cutting knife to endure. From what I've seen the high wear resistant steels will chip like crazy and you won't be happy you spent so much on them. Cardboard cuts easy. Anything you can rip with your hands is not much of a test for a knife. Yeah, it's abrasive but it is still not tough. A thin dull very tough knife will still cut it easily where a harder more wear resistant steel will chip on variables and the cardboard itself. In every case I've seen the trade off to wear resistance is toughness.
Yes one does better in a no variable human factorless test, but them variables are what defines what you look for a knife to work through for a work knife. Even if you have to touch it up at the end of the day. Atleast there is an edge to sharpen instead of a chipped out damaged one.
Worked around cardboard for half of my life in the Grocery business.
Dealt with it with a lot of different things over time from jiffy cutters, safety cutters to all sorts of knives in different steels.
I don't agree because dull is just well....... dull.... And have only seen a few very small chips (contacting hard steel), more rolls here and there.
I found that s30v had done more and lasted long enough for me doing that type of real work. I might have had to touch it up like once a week stropping the edge a few times for the most part. I kept it at a pretty high level of sharpness, phonebook paper cutting sharp or it was touch up.
Not so sure about ripping triple wall and better cardboard by hand..... Can hardly bend some of that stuff and pretty much stand on it without it bending.
