I’ll take em! I use a lot of black walnut, thank you! I’ll take the blocks if another person chimes in wanting some.
Me too!!! I hand sand it and then apply butcher block oil afterwards.Good Score, and Very generous give away..... I use it unstablized. I don't want the extra weight.
One of my favorite woods!
Id use it for sure, but TheEdge won it fair and square.... It's His.So .... is TheEdge01 the only one saying they actually want some of this? If so, I will see what I can fit into a medium flat rate box.... (otherwise I will divide the total amount....)
I’ll take the blocks if you want the scales, I have plenty of flat pieces.Id use it for sure, but TheEdge won it fair and square.... It's His.
again, you are very generous.
*He Better show pictures of it being used though.....lol
I originally said i would divide it if more than one person wanted some. Im not sure it is really fair to operate with first-to-reply gets it (cant assume when someone will check the website … so ill divide it between you two. Can you each pm me with your mailing addresses?Id use it for sure, but TheEdge won it fair and square.... It's His.
I can’t send PM’s, but I can email my address to you.I originally said i would divide it if more than one person wanted some. Im not sure it is really fair to operate with first-to-reply gets it (cant assume when someone will check the website … so ill divide it between you two. Can you each pm me with your mailing addresses?
Crag - you are most welcome .. i would not want to see the wood go to waste!
You are welcome. Enjoy!It has arrived!!! Thank you Cushing! I really appreciate your generosity! When I put it to good use, I’ll post a pic.
Im not sure what you mean by bumping the icon?Did you bump the icon that liks this, [ ]? I did that recently and co8ld get my photos to work either.
When you write your posts, there are three dots in the top right corner. If you hit that, it opens a sub menu with the [ ] icon. This apparently disables code and wouldn't let me post photos. Hitting it again turned everything back on.Im not sure what you mean by bumping the icon?
