and then grinding. One benefit of quenching the blade after the last thermal cycle is that it really softens up the scale. Actually, most of it comes off. So there's very little grinding to do.
After grinding the blade flat and straight on the belt grinder, the shape is marked on with a Sharpie, and the extra material is cut off with the bandsaw:
Then the profile is cleaned up on the belt grinder, and the edges are painted with Dykem:
I'm enjoying the trip through the various stages. Thanks for taking the time to do a WIP. They require a lot of extra time and we all appreciate the effort.
I especially like your way of getting different thicknesses of layers into the twist. I'm looking forward to seeing the final product. I'm sure that many don't realize how much extra time and waste that is involved in making various patterns.
Philip, thank you for the WIP! I've developed an appreciation for grinding from watching all of you guys and I have to say, yours are really nice, you make it sound and look so easy! I can't wait to see the finished knife.
Thanks for tuning in, fellas. Sorry I haven't posted much lately. I don't do much on knives on weekends, and I have some other projects going too. But I did harden the blade (actually four blades) last Friday, and finished tempering over the weekend. But that's getting ahead of myself. First, grinding. Didn't get any action pics, but here it is with all of the blade except the "inside" curve ground to 240 grit.
Here it's all done:
and here I've filed in the guard shoulders. Sorry, no pics of that either.
Have to file in the serrations before heat treating, for obvious reasons. Here I've layed them out with a sharpie. The marks are 1/8" apart.
And here I've started the grooves with a three corner file.
Then the main bevels are ground (using a fresh 60 grit belt) until the guide bevel is gone, then again with a fresh 240 grit belt.
Then it's time to hand sand. Here's my sanding setup:
I have several different sanding sticks. I have flat ones for doing the flats (imagine that!) and convex ones for doing the recurve. I have a set each of hard and rubber coated. I use the hard ones for blades like this one that has a double grind, for keeping the grind line sharp. I sanded lengthwise with 400 grit paper until ALL the 240 girt scratches are gone.
