We have had enough of Cliff and his "scientific testing". If you wish to defend him or criticize him please do it elsewhere.
KenM K said:One could argue that this forum is biased.
Sounds like a tall order.
You have to read those reviews and tests very carefully. There are things he does that are easily missed or misunderstood that have a large bearing on the results. For example, he gave the small Sebenza some bad marks for edge durability in some tests. But hidden in all the talk (or at least just stated in passing) is the fact that he had sharpened the blade to something like 6 or 8 degrees per side, and then cut plywood across the grain. That is a smaller included angle than a straight razor! Who actually uses a straight razor to cut plywood across the grain? We're not talking about utility knife razor blades, we're talking about straight razors used for shaving.
The point made was that another blade sharpened to a similar angle (O1 steel, if I recall correctly) fared much better. That may be so, but it is not especially surprising given the properties of O1 vs S30V (much finer grain, and tougher). But in the mean time, Chris Reeve gets a bad name because someone heavliy modified a Sebenza and then put it through things that most people would not even consider.
Ok generally that it is. And Cliff is applying to unknown facts? As far as I can tell most of the ppl have a beef with his methods when their favorite knife fails.Science is relating and applying known facts.
How can you make that statement w/o being there, i.e. watching Cliff do all that?Not twisting facts to meet a pre disposed result.
If your experience is limited may be you're not right about this forum not needing his input?Even with my limited experience I could see through his babble. This forum does not need his input.
I respect Cliff for his often rational thoughts concerning knives, and the information he has accumulated, organized and posted for the benefit of people like us. <snip>
I also like his approach. He is interested in performance, not obsessing over looks, fit and finish, style, sexiness or other irrational attachments people have developed towards their tools.
On one hand, I'd like to do some more detailed testing work myself, but I'd be really apprehensive about even posting it here. Any man who tries doing something like that will be ridiculed and heckled by a large number of people here.
I have seen knives here, sometimes as many as three of the very same model in the very same steel, and each one gets a unique and different review because each one is a separate entity
STR
The most important thing I learned from the Cliff or Noss style knife tests is that thick knives made of tough steel are harder to break than thin knives made of not so tough steel.
Was that a real eyeopener for you ?
Ok, I figure you didn't read Cliff's reviews, you just looked at the pix. Common practice amongst his criticsThe most important thing I learned from the Cliff or Noss style knife tests is that thick knives made of tough steel are harder to break than thin knives made of not so tough steel.
