tony281sc2
- Feb 13, 2017
I like having a lockbar insert on frame locks (some liner locks have them too), mostly for peace of mind in case the lockup ever gets too late. I’ve had a couple older ZTs that moved to about 75+% and I don’t like that, because if it wears more, then I don’t even know how they would fix the blade play in that case if it were to develop.So you like the lockbar inserts not so much for their ability to keep the lockbar from overextending in the opposite direction that it locks up, like as if you were to push too hard when unlocking it, but it's ability to keep the lockbar from kind of wiggling back and forth on heavy cutting? And I mean back and forth as in not in the natural direction that the lockbar travels when locking and unlocking, but the other direction? I'm not arguing or anything, I'm just curious why you like it for keeping the lockbar from traveling all the way to the opposite liner and causing blade play, or rather why the lockbar stabilizer would help when the lockbar is traveling that way, considering I think usually people think of the stabilizer as helping in the other direction. Maybe you can give me some more appreciation to the Lockbar Stabilizer.![]()
Whereas if it had an insert, it could easily be replaced with a slightly bigger one, and then you’ll have another 5-10 years before you wear that out too, maybe longer.
It was a Chinese Kershaw, nothing expensive, but what would happen was after a few heavy cuts, the frame would move over so much on deployment that I needed a screwdriver or similar tool just to unlock it.Is the issue that you have lock failure or just late lockup?
As Shinyedges noted, the newer CRK's have a patented ceramic ball interface that's even harder and more resistant to wear than a steel insert.
I’ll have to check out that ceramic ball interface you guys mentioned…. I’m embarrassingly unfamiliar with CRK in general
