A.McPherson
- Jan 27, 2012
Purple Heart. At least that’s what it looks like to me...
You are absolutely right 100 is almost exactly where it is. (Reminds me of the guys behind the meat counter who reach in and grab exactly 1# of ground beef - thats experience talkng!). The question though is, is i want to somewhat accelerate things (with risk i know) what temp do i want to aim for? 120 maybe???With a 75W bulb, a box the size of yours should warm to about 100F. The front panel should be reasonably snug to prevent air escaping along the sides. You want the air to flow up the box and out the top hole. Eight 1/4" holes (2 per side) on the sides near the bottom will provide new air.
Thanks Stacy. Right now i am not so much drying as needing to drive the equilibrium water content lower than ambient will allow so i know i am either ready to stabilize or use the wood as is knowing it is not likely to shrink much more. I need higher temps to do that. The few pieces of wetter wood i have will not see the inside of that cabinet for quite a whileI wouldn't try to speed up drying .
Everything comes to he who waits - Disraeli
I too remember the Easy Bake Ovens, - which means I have just dated myself for the forum....Soft wo0ds, like construction pine and fir are dried between 100° and 115°, while hardwoods are dried at 80°F.
BTW, I was wondering if the info you read from Boye was to use three 50 watt bulbs ( not a single 350W bulb)? A 350 watt bulb is a huge and very hot bulb.
I remember the "Make and Bake" oven of the 1950's. It was a foil and insulation lined girls oven that used a 75 watt light bulb for the heat
Knots can make twisting/drying more likely to crack. There are so many variables with different woods, seasonal differences etc. that’s why I set pieces to dry 1” per year...
I bought a large maple burl slab to process and send to K&G. Also grabbed a moisture tester, but my question is what setting do I use to test it? It has multiple settings for different woods, any idea how to find the base species to test this as?
