CJT - sorry - I should have posted these a while ago. Here is the box from the outside:
Originally I thought I would put that front panel on hinges ... but then decided it was just as effective just leaning it up against the cabinet. right now I just have tape holding the thing on, but do have some velcro strap (for whenever I get around to attaching it to the cabinet). Other than the hole (1") in the back for the controller plug wire, I did not cut holes in it - am relying on the gap between the front panel and the sides of the cabinet to give me some air exchange. the controller (bottom right) is just a simple thermostat controlling within 5 degrees (I figure for this application a PID controller would be way overkill). I have thought of putting insulating foam on the sides, back and top ... but have not gotten around to that either :-(
the inside looks like this:
Wire racks from home depot with the back rail attached to the rear upright 2x2's with through bolts. I can add more racks if needed, but dont need them yet. Keeping them high also gives plenty of room between the shelves and the ceramic space heater that heats the thing. I know it is often spoken about heating these with a 75-100W lamp ... but when I went to Home Depot there was not an incandescent bulb to be seen! (all LED's). I had this heater sitting around, so I figured "why not". (you can see I located the hot output side a ways away from the side of the box). I monitored the thing very closely when I first fired it up ... and the sides of the cabinet get nowhere near warm enough to be a concern. This little heater gives me both heat, and air circulation. It appears to work very well: spalted maple I put in there for stabilizing went from 10% moisture to not-measureable within a couple days. More dense wood (like black walnut) took less than a week to get to not-measureable moisture. really dense woods, like true rosewoods, take much longer ... but so far I have seen that if you put them in there with 15% or less moisture then have not split on me. Some of them have twisted a little .... but so have some of the pieces I have sitting out in the basement.
I have had the thing up to 120F when I was drying wood for stabilization, and the heater had no problem maintaining that temperature. Most of the time I just leave it sitting at 90F.
