Matthew Gregory
Chief Executive in charge of Entertainment
- Jan 12, 2005
I'm not sure this is exactly what your intention was with this thread or not, Nathan, so if this is digressing, PM me and I'll erase this post.
The folks that keep having Park's 50 thrown in their faces are being much maligned here, and needlessly so. Perhaps the zealot behavior ascribed to them is the result of something, just the same as the position many have expressed in this thread. I think what's being overlooked is that even those science guys can appreciate the 'art' as Makermook describes it... what they might take issue with is the staunch refusal for someone to accept new information because it doesn't support their own worldview.
Case in point: many moons ago a well respected knifemaker and writer produced an article providing a review of a new forging steel. Rather than considering the instructions provided by the company that made the steel, he insisted on applying his 'tried and true' old-timey methods (which, for the record, don't even approach the recommended heat treatment of the steel) and experienced questionable results with it - stunning!
When I protested his methods, and provided him with the scientific documentation (that was made available to him before his testing, unbeknownst to me), I was met with this:
I should have had a disclaimer that edge quenching in (quenchant name omitted) is only for the most experienced and certainly not recommended for those with digital controlled furnaces and real quench oil. However, I suggest that you do not blindly trust your high tech equipment. Be sure to test your blades in actual using conditions against blades of known value.
If digital controls and special quench oils were the only way to get good results I doubt that the US could have beat the British in the Revolutionary War. How about the knives that lasted Lewis and Clark through their two-year adventure? Do you know how the blades were heat treated that helped the US win WW1?
The quote in italics have been edited only to remove personal information about the writer to make a (feeble, I guess) attempt at maintaining his anonymity.
1- The author didn't follow his own advice and establish a known baseline reference by following the instructions first (thereby following known data, same as you do with your treatment of D2), unless we're required to start from scratch and ignore the wisdom of those that came before - something I find more disrespectful than calling bullshit on someone that doesn't have enough common sense to learn from others...
2- The control over alloying elements was questionable, at best when we fought the Redcoats. Simple steels have much simpler heat treat requirements - assuming you're even willing to meet even those requirements!
3- Lewis & Clark regularly injected massive quantities of mercury into their penises via a catheter to alleviate the symptoms and cure venereal disease - the cutting edge of their science, at the time. Perhaps the wisdom of their age has been surpassed a pinch?
Is this man's position in defense of his 'art'? Have you considered edge quenching your D2 blades in (quenchant name omitted)? Perhaps that's why you're not getting the same results as Mr. Dozier, although I doubt you'd consider doing that.
Quoting Mr. Dozier from a post he made years ago on another forum:
Any steel co. will give instructions on heat treating D2. Your best will be to temper at 600 t0 700 - 2hr's.- twice or three times if you feel the need to. The edge holding ability will not be as good at this hardness but will be tougher. I like the higher hardness for edge holding and high strength.
There is no secret, only close control and the need to be exact with every thing you do.
Please don't misunderstand me - it's not my goal to start the art vs. science war again. To prove my point, I'll show you a picture of my 'grail' blade... the one I'll never own, but shall forever hold in envy and awe:
The scientist in me is still capable of understanding that the art represented here is entirely intertwined with the function. I hold out no hope to ever be able to achieve something so extraordinary.
