I already posted that link but here it is again , i don't know what i was thinking when I bought that mammoth pins which are 10mm Dia . Now I think that they are to big size for this knives ...Please post the link to the seller of those Corby style bolts.
My concern is that once the bolts are installed and sanded flush, there is no way to etch them to get deep topography without destroying the scales. The sanded and polished pattern will show faintly, but not like it is when etched.
There is one alternative, which is to cut the slot in the heads deep enough so it will allow removal after sanding. Then you can etch the ends and re-install them in the handle. The final polishing of the handle should not affect the etch if done gently.
Griff Zubehör kaufen | Messerschmiede Gobec
Griff Zubehör jetzt online bei Messerschmiede Gobec kaufen. ✓ Große Auswahl ✓ Schnelle Lieferung ✓ Auf Lager
www.gobec.at
You just give me idea about pins .It will work for me because I will not pay anything to do that .I can do on EDM torx on both head on pins , then after I sand them in final dimension I can do etch . I will try first what I already posted in previous post , I think it can be done that way .
