My girlfriend actually let me use my EDC on it.
You need permission?![]()
Not exactly....a toothy edge is more like just the spread fingers of one hand. Even folks like the infamous Cliff Stamp will tell you that a properly apexed (burr-free) low grit edge will have increased slicing aggression than a high grit edge, as well as increased edge retention on slicing tasks.
Ok. So I've posted about this before, but ran in to a problem the other night. I prefer a toothy edge over a polished one. I got a huge New York strip and the knife they gave me was so dull it basically didn't work. My girlfriend actually let me use my EDC on it. It cut through like the steak was air. I know better than to drag it on the plate. Either way - the blade was noticeably duller afterwards. Duller after cutting steak?!? What the hell? It's a small sebenza?!? Do you guys think it's the whole 'toothy edge' thing? Bad heat treat? (probably not).. what ever the reason - I'm pretty pissed and don't understand how a steak can dull a knife. Please help! (oh yeah - I'm running 17 DPS on it - figured that's fine?)
I used to do the xc, c, f, ef diamond and 2000 sand paper followed by stropping. It made beautiful hair whittling edges. However, certain materials were immune to such edge refinement. Now I agree about aggressive edges. Right off the 600 grit fine DMT and just a few very light passes on stropman white. Time to cut!
The knife isn't even dull. It just needs to be honed on either a strop or a Steel. A "toothy" edge is an unaligned edge. Take your hands and interlock your fingers with them sticking out.
Like this
This is a what a Toothy edge looks like if you are lucky. Most likely, half ass sharpening a blade will leave a wire burr.
The "teeth" need to be aligned-by either a Steel or a strop. Skip that step after the stone, and you are going to end up with fools gold for the edge. It will seem sharp, but its really isn't.
Charred steak is carbon. Diamond, the hardest material is carbon
Explains it all
Sebenzas are definitely not known for their edge holding, but toothy is dull bullshit. Polished is just sharper and better. A perfect mirror is the best.
Hi,We might have a terminology problem here. Most people here say "toothy" when they mean a coarse edge. That is, an edge that has been sharpened with a relatively coarse stone, and apexed properly, and had the burr totally removed. You can do this at 80 grit, 100, 400, or 600 ... no burr .. easily shave arm hair, without much resistance
Hi,
actual arm hair shaving in this one Knife sharpening : 36 grit dressing stone - Cliff Stamp
