edges off coarse dmt are amazing,easily shave hair too.
One thing to watch out for is the difference between a coarse edge at a given grit value and an edge that has been crafted from a coarse stone to behave as a more refined one. If an edge is cutting like a more refined one, then it is no longer cutting like a more coarse one - sounds obvious but there are implications.
Another consideration is the extreme variation in line viewed from the side, a by-product of the relatively low concentration of abrasives and high unit pressure make it difficult to produce intersections at the low points that are 100% burr free (this speaking to the macro-coarse edges) - it is difficult or impossible to work the same point from opposing sides, only the high spots primarily experience this (imagine corrugated roofing with an edge cut into it, now flip). This is relative - an abrasive field with high friability/refresh rate and some vehicle (lube or binder) will behave differently from one that lacks one or both of these traits.
On the plus side, even if they do have small burring they will still cut very well, and protected by the higher points to either side tend to have good longevity as well. Particularly excelling in relatively shallow, drawing cuts on light to medium density materials or ones that aren't held together tightly, allowing less pressure to be used.
As the density and hardness of a target material increase, the variation in line that lets it cut so aggressively becomes a hindrance as it increases friction and drag. This is where a refined edge comes in and parts the material with less pressure - all things being equal.
Not to overthink it, but steel as it pertains to a cutting edge is basically a kick-butt micro-sculpting medium.
What happens if we put a coarse finish on one side of the bevel and debur with a fine stone on the other? Best of both worlds?
In my experience a coarse edge of say 280 grit lansky can push cut remarkable well if carefully deburred and finished with light strokes.
Comparing surgery on a living human being to cutting a steak is a bit silly don't ya think?I guess the truth is funny? Must explain why for precise cutting tasks, surgeons use ultra fine obsidian scalpels...because they are inferior slicers to ragged edges?
I guess I'm going to hear next how 2 cycle engines, can run for more operating hours that diesel engines.
I will concede that the internet is funny.
It's all muscle...Comparing surgery on a living human being to cutting a steak is a bit silly don't ya think?
It's all muscle...
