tattooedfreak
Steel mutilater is more like it.
- Mar 12, 2010
Ok, here's the scoop; I have a 1hp general purpose motor, 115/230 running 13.6 a/6.9 a. I wired it for 115 to start but when I put a load on it, it trips the circuit, of course. I recently put in a sub panel running off a 40 amp breaker. I used a quad breaker with 2 single pole 15a and one double 15/240. I wired a single 15 for general purpose and the double for my motor. I rewired the motor to 240 and plugged it in, no run. I switched out the plug to a 115, rewired the motor to 115, runs fine. Switched back, nothing. Did the switch once more to 115 (in case I am cracked) runs fine. I havent tried it with a load yet, that is the next step. Switched once more to 240.. nothing. Is there something I'm missing? Im using 12/2 wire in the panel and 14/2 at the motor, is that the issue? I can't see that as it only uses 6.9 amp at 240. Please help.
