DeSotoSky
- Mar 21, 2011
Thanks. I didn't know it was birch. I always thought it was rosewood. I was wondering if the blade was 440C? It very much looks like the 440C steel Buck used in the 60s and 70s.....
A couple more things. Pretty much all Dymondwood is resin impregnated birch laminate. Buck plays it a little loose with the handle naming, Cocobola, Walnut, Rosewood etc are actually the dye color, not the wood species, so yes, you could call your handle 'Rosewood' refering to the color. If you look closely at your handle on edge you can see the laminate layers, about 25-27 per inch. Now about the steel. A lot of changes took place about 1981. The handle changed from micarta to birch, the steel changed from 440c to 425m, and the guard changed from pointed to blunt (like yours). In "general" it can be said that micarta handled Kalinga's are 440c and later wood handled Kalinga's are 425m...but.... what happened at the time of changeover? Using up the last of the 440c blades with the new wood handles etc. so I imagine it is theoretically possible to have a 440c blade with a birch handle. I do not know if there was a visible difference between the 440c and early 425m blades. Anyone else know? Does it really matter? /Roger
