bladegrinder
- May 4, 2013
Have you tried facing the brushes like I described earlier?
Hmm, it remains a mystery. Before giving up, I would double-check the jumper and trimpot settings on the drive. The motor voltage selector is factory set to 90V, did you change that to 180V? There is also a motor current jumper and current limit trimpot that need to be set correctly. The factory settings should be ok, but it can't hurt to double check if you haven't done so already.Piece of cake. No problem with idler or platen pulleys.
