aproy1101 said:You guys have me somewhat confused. Do a search for the thread called Handle Treatment. Dave Rishar does a drawn out description of his process for each handle type. Its a goodun. I use mineral oil then Danish oil on my horn khukuris. For antler I use carnuba wax only. For wood I use danish oil, and sometimes Tru-Oil after the Danish Oil has THOROUGHLY dried (several days). I am not the expert here gents, they are Steve Ferguson and Dave Rishar. If you want to know for sure get it from the horses.........![]()
aproy1101 said:Keep wicking in the super glue. Once you get a good bit in there start sanding between wickings and letting the dust collect in the crack with the super glue. That'll fix it, but you may be able to see the crack. The other option is to color some epoxy and fill it that way. DON'T USE 5 MIN EPOXY FOR THIS APPLICATION. Horn is translucent when thin, that's what the yellow is as far as I can tell from the description. Treat your horn handled khuks with mineral oil and danish oil to prevent cracks. I'll find the thread for you.
aproy1101 said:Got it. Searching is always a pain for me too, but if you goto the advanced search section and are really patient...
http://www.bladeforums.com/forums/showthread.php?t=371806
arty said:Watco will do it. Four coats with 8-10 hours between will seal horn so that it won't crack.
FIrst, seal the cracks with superglue, then use Watco. It may help to leave the stuff on for at least an hour before you wipe off the excess.
I got the idea to use Watco on horn from Erik Estus, a bladesmith.
It works, but 2 coats may not be enough.
