Decided to make my own knife...advice would be welcome
Hello all,
After a bit of thought I have decided to make my own knives. I have dozens of different knives from cold steel to Busee combat, and still I keep looking for my perfect knife. I decided that the only way I am gonna find the perfect knife is to make my own. Now i have no illusions of forging or heat treating my own metals. I found a place that I can get pretty much any type of metal and they will laser cut a knife blank, and heat and cryo treat it for me if i send them the specs. I decided that this would be my best option. What I want to do then is grind out the bevels and edges and then create my own g10 scales for the knife. To this end I have a 8" bench grinder and a whole plethora of dremel tools that I can work with. I was going to use the bench grinder with different grit wheels to remove the excess material from the knife blanks and then switch out the grinding wheels with buffing ones to put the final finish of the knife. I was then going to purchase g10 stock and use my dremel tools to cut and shape the handles for the knife. ( I am aware that a respirator is required to work with g10). So thats the general idea. Any advice to helping me accomplish this would be very welcome.
I would like to create 3 knives as a sort of set Knife specs:
Knife 1: d2 tool steel, 1/4" stock, 12" blade length, 18" overall length, g10 handles,
Knife 2: d2 tool steel or high end damascus (other suggestions and opinions welcome), 1/4" stock, 6" blade length, 12" overall, g10 handles,
knife 3: high end damascus or CPM S35VN (other suggestions and opinions welcome), 1/4" stock, 3.5"-4" blade length, 8.5"-9" overall length, g10 handle
So is there anything I missed or haven't considered. Is there a specific tool i should be using? any particular type of grinding wheel or buffing wheel I should use/not use? where would I get these items? And any other general advice would be very welcome! Thanks so much in advance!
Man, I know that people have used bench grinders to make knives, but I wouldn't expect a very good looking knife if you decide to use one. Couple that with 1/4" steel and you have a really bad idea.
The other guys here will hate me for this, but if you HAVE to go through with this plan, at the very least, get a 1x30 belt grinder and good belts.
Scrap all of it though and read the stickies. If you're lucky, the Count will be by to give you his list of recommended reading. Save yourself an enormous amount of headache and read (and follow!) the advice in those threads. I'm a fairly hard headed fellow and started with ridiculous steel (1/4"). I listen now.
Imo, the fastest way to accepting the stickies as fact is to ignore them once. ;)
And this is why I posted this thread...so belt sander...I have been considering one...any recommendations looking to spend no more then 400 on the belt sander.
Is the steel choice the issue or the thickness of the metal the issue? I know the knife i want would be about a 1/4" thick...are you suggesting i start with something easier to practice on and then move to 1/4" thickness?
^^^^^^That......and this: Put your ideal knife projects off to the side for now. I think a lot of new guys, not necessarily you, but a lot of guys think a knife is just a sharpened piece of metal. How hard can it be? Man, those people are not just wrong, they are WAY wrong. You are NOT ready for your dream project yet. Make some small knives out of 1/8" stock. Pick a eutectoid steel like 1084, 1075 or 80CrV2(1080+). If you don't know what eutectoid means or why that is important that is another indication that you need to do some reading before you begin. I know you are going to send the blade out to be heat treated but it is better to learn and make mistakes on less expensive steels. Plus the steels mentioned make darn good blades. It's good that you decided to make your own knives but it will humble you quickly. The best chance you can give yourself is to do a lot of reading and collect some tools and supplies before you begin. Step 1, go straight to the stickies. Do not pass go, do not collect $200. Good luck and welcome.
A 1 x 30 belt grinder will cost around $40 if you get one from hf if you want to spend money a sears 2 x 42 belt grinder will also work and for steel I would get 1080 or 1084 and get no thicker than 1/8 steel for your first 5-10 knives (that is not finished product that is 5-10 attempts to make a knife not 5-10 knives) this is just an opinion take it or leave it -calvin
"Is the steel choice the issue or the thickness of the metal the issue? I know the knife i want would be about a 1/4" thick...are you suggesting i start with something easier to practice on and then move to 1/4" thickness? "
I believe that form follows function, so it depends on the use for the knife. To start, make your small knife out of an inexpensive steel (O-1, 1084, 1095, etc.). This is a practice run and these steels are easier to work than the D2 or s35vn. Use a thinner steel, get used to the process. Don't worry about G-10 scales for this knife. If you goof up on this one, change your design. Send it off to HT, finish it up with some pakkawood scales. Do the same with the next largest knife, making it better than the first. When you finish you will have 3 functional knives and some experience. You'll learn which belts to use, how to mount the scales so you like them, where to send blades for HT, and etc.. Then buy some new belts and that expensive piece of D2 and have at it.
Think thin. Thin wins...
1/4" thick is utterly overkill for something that isn't going to be used as a prybar. I think you underestimate how thick 1/4" really is, and how strong and tough a properly HT knife can be.
The tactical knife in my sig is 5/32" and has been used as a step for a 200# guy in full tac gear...
Cheers.
So ordered a 4x36" belt sander and a number of different grit belts for it.
I can understand going with a smaller and thinner knife to practice on so ill order some 1/8" 1080 stock to just practice my technique on and see if i can make this a reality. But for the final product i am set on the 1/4" stock.
Please keep the comments and advice comming I really appreciate the help and guidance!
The Count's Standard Reply to New Knifemakers V31
The answer to a 13 year old student is different than a 60 year old machinist
We have members worldwide, you may have a local supplier, hammerin or helpful neighbour.
Please join our community and fill out your profile with location (Country, State, City), age, education, employment and hobbies so we get a sense of where and who you are.
Look at the threads stuck to the top of the page.
The basics in the simplest terms
Absolute Cheapskate Way to Start Making Knives-Printable PDF-Right Click and Save http://www.2shared.com/document/hk4wQruA/Absolute_Cheapskate_Way_to_Sta.html
http://www.scribd.com/doc/3622507/Jones-Scott-Jonesy-Absolute-Cheapskate-Way-to-Start-Making-Knives
Web Tutorials
Detailed instructions by Stacy E. Apelt http://www.bladeforums.com/forums/showthread.php?t=694673
The Things I Advise New Knife Makers Against-Printable PDF http://www.mediafire.com/?8og1ix21j9dcz4n
Handle Tutorial - Nick Wheeler-PDF http://www.mediafire.com/?02ra4do6xyzayeq
http://www4.gvsu.edu/triert/cache/articles/nw1/scales1.htm
Bob Egnath how to http://www.engnath.com/manframe.htm
Books
A list of books and videos http://www.bladeforums.com/forums/showpost.php?p=9435307&postcount=43
BladeForums - E-books or Google books http://www.bladeforums.com/forums/showthread.php?t=603203
Books I like:
David Boye-Step by Step Knifemaking
Tim McCreight-Custom Knifemaking: 10 Projects from a Master Craftsman
Clear, well organized, widely available and inexpensive.
Knife Design:
Think thin. Forget swords, saw-tooth spines, guthooks, crazy grinds and folders for your first knife.
Start with a drawing and show us, we love to comment on photos.
Then make a cardboard cutout template & draw in handles, pins and such.
Use playdough to shape a comfortable handle, good handles are not flat.
How to post a photo
http://www.bladeforums.com/forums/s...AL-Displaying-your-photographs-on-BladeForums
Google books thread for Lloyd Harding drawings, Loveless book & Bob Engnath Patterns. http://www.bladeforums.com/forums/showthread.php?t=603203
Bob Engnath Patterns in a PDF http://www.mediafire.com/?qgx7yebn77n77qx
Forging Books:
Lorelei Sims-The Backyard Blacksmith - A modern book with colour photos - forging - no knifemaking.
Jim Hrisoulas- Check for the cheaper paperback editions.
The Complete Bladesmith: Forging Your Way to Perfection
The Pattern-Welded Blade: Artistry in Iron
The Master Bladesmith: Advanced Studies in Steel
Machine Shop Basics -Books:
Elementary Machine Shop Practice-Printable PDF Http://www.archive.org/download/elementarymachin00palmrich/elementarymachin00palmrich.pdf
The Complete Practical Machinist-Printable -1885-PDF http://ia700309.us.archive.org/6/items/completepractic00rosegoog/completepractic00rosegoog.pdf
Right Click and save link as.
It’s being reprinted now if you prefer paper books
The $50 knife Shop-not reccomended
This book has a great title, but is NOT gospel. It confused me for a long time.
Forging is NOT necessary; you can file and grind to create a knife (stock removal)
Forget the Goop Quench BS, Even back when they used whale oil, it was still liquid oil.
Use a commercial quench oil & match oil speed to the steel type;
Grocery store canola oil works for some steels like 1084.
Junkyard steel requires skill and experience to identify and heat treat it properly.
Forget Lawnmower blades and railroad spike, start with a new known steel.
Good heat treating needs accurate temperature control and full quench.
You can buy proper steel like 1084FG from Aldo very cheaply, and quench in Canola.
Cable damascus is an advanced project has no place in a beginner’s book.
The grinders are the best thing about this book, but 2x72” belt grinders free plans are now on the web.
Videos
Don't be this guy
http://www.youtube.com/watch?v=gEOTtslHARQ
Heat Treating Basics Video-downloadable
Right click and save this. Watch it once a day for 10 days. http://www.archive.org/download/gov.ntis.ava08799vnb1/ava08799vnb1_512kb.mp4
Safety-video
Right click and save this. Watch it once a day for 10 days. http://www.howtomakeaknife.net/FreeStuff/SafetyVideo.wmv
Many knifemaking videos are available, some better than others.
The best beginner videos I have seen:
“Steve Johnson-Making a Sub-Hilt Fighter”
"Ed Caffrey - Basic Bladesmithing-Full DVD-ISO"
“Custom Knife Sheaths -Chuck Burrows - Wild Rose”
-(Paul Long has 2 videos, his sheath work & videos are fantastic, but more advanced-with inlays, machine stitching)
Green Pete's Free Video
Making a Mora bushcraft knife, stock removal, hand tools, neo tribal / unplugged heat treat.
Use a piece of known steel, not a file. This as an example of doing it by hand with few tools.
"Green Pete" posted it free using torrent files.
Be sure to look at the other titles I mentioned too - spend some time searching.
Greenpete Knifemaking Basics-on TPB
http://thepiratebay.org/torrent/499...femaking_Basics_-_Make_a_Mora_Bushcraft_Knife
How to download that video
http://www.utorrent.com/help/guides/beginners-guide
See a list of videos for rent and read the reviews, Some are good, some bad, expect to wait weeks or months
http://smartflix.com/store/category/9/Knifemaking
Draw Filing Demonstration
YouTube video -Draw Filing-for a flat finish http://www.youtube.com/watch?v=Dec78RQsokw
Steel
The “welding steel” at Home Depot / Lowes… is useless for knives.
Forget about lawnmower blades ,files and other unknown junkyard steels.
For all the work involved, it is very cheap to buy and use a known good steel.
If you send out for heat treating, you can use
Oil quenched O1, 1095, 1084
Or air quenched A2, CM154, ATS34, CPM154, 440C, plus many others.
For heat treating yourself with minimal equipment, find some Eutectoid steel and quench in Canola oil.
1084FG sold by Aldo Bruno is formulated for Knifemaking, Cheapest & made for DIY heat-treat.
http://njsteelbaron.com/
Phone # 862-203-8160
Suppliers List
http://www.bladeforums.com/forums/showthread.php?t=699736
Heat Treating
http://www.bladeforums.com/forums/showpost.php?p=9143684&postcount=7
You can send blades out for heat treating at $10 or $15 per blade for perfect results, and avoid buying the equipment.
Air Hardening Stainless Steel Only
Buck Pau Bos -Be sure to check the Shipping and Price tabs.
http://www.buckknives.com/index.cfm?event=bio.paulBos#
http://www.texasknife.com/vcom/privacy.php#services
Oil Hardening Carbon Steels and Air Hardening Stainless Steel
http://www.petersheattreat.com/cutlery.html
http://www.knifemaker.ca/ (Canadian)
FAQ's
http://www.hypefreeblades.com/faq.html
1095 is a good carbon steel, but a bad choice for a beginner with limited equipment.
1095 is "Hypereutectioid" and needs very precise temperature control and proper fast quench oil Like Parks 50 or Houghton K
Kevin Cashen - 1095 - hypereutectoid steel http://www.bladeforums.com/forums/showthread.php/673173-Working-the-three-steel-types
If you are sending one or 2 knives out for heat treatment, use 154-CM or CPM-154 or CPM-s35vn and ship it out to TKS -Texas Knifemaker Supply
It's the cheapest way to do 1 or 2 because of HT minimum charges.
Quenchants for Oil hardening steel
Forget the Goop Quench and Motor oil.
Use commercial quench oil & match oil speed to the steel type;
The best explanation and classification oil speeds I've seen
http://knifedogs.com/showthread.php?28197-Hardening-II-Quenching
Grocery store canola oil works well enough for your first knife-if you use the right steel like 1084
Brine and water are cheap, and technically correct for "water hardening" steels W1 and 1095 but a fast oil like Parks 50 or Houghton Houghto Quench K are less likely to give you broken blades
If you use water or brine, expect to hear a "tink" and have a cracked or broken blade
Glue – Epoxy
Use a new package of slow setting 30 min to 1 hour, high strength epoxy to attach blades to handles and seal out moisture.
Slow epoxy is stronger and gives you time to work with it.
Surface Prep is vital, drill tang holes/ grind a hollow, roughen the surfaces with abrasive or blasting is best.
Ensure the surface is clean and no oil including fingerprints.
Use Acetone & Alcohol, or Blasting.
Don't over clamp it. Avoid a “glue starved joint” when all the adhesive is squeezed out.
Use:
Brownell's Acraglas
West Systems G Flex
JB Weld
Grinder / Tools
Hand Tools
You can do it all by hand with files and abrasive cloth like the Green Pete video.
Just use 1084 instead of a file.
Stacy - 10 Tools
http://www.bladeforums.com/forums/showthread.php/1049666-Ten-Tools?p=11983527#post11983527
Photo of a nice bevel filing jig
http://www.flemingknives.com/imagesPrime/FileStation/KPicB007.jpg
Http://farm9.staticflickr.com/8486/8152684286_312b9fc8da_b.jpg
http://www.youtube.com/watch?v=r9iNDRwwBQQ#t=330
Grinders
A professional three or four wheel 2x72 is worth it
In my opinion, variable speed and a small wheel attachment are essential on a good grinder.
You can almost always improve tracking with more belt tension. It needs to be way tighter than you first think.
Entry Level Grinders
Sears Craftsman 2x42 belt grinder http://www.sears.com/shc/s/p_10153_12605_00921513000P?prdNo=3
Low Speed Modification Craftsman 2x42 belt grinder http://www.youtube.com/watch?v=2qfYT_m2Tw0
Commercial Production 2 x 72” Belt Grinder Reviews
http://www.prometheanknives.com/shop-techniques-3/grinders
http://www.cnccookbook.com/CCKnifeMakingGrinders.htm
DIY 2 x 72” Belt Grinders
KMG Clone Free Plans
http://www.metalwebnews.com/manuals/knife-grinder.pdf
NWG No Weld Grinder
http://usaknifemaker.com/plans-for-the-no-weld-grinder-sander-nearly-50-pages.html
EERF Grinder (EERF =“Free” backwards)
http://www.wilmontgrinders.com/Pages/EERFGrinder.aspx
http://blindhogg.com/blueprints.html
Buy the kit
http://polarbearforge.com/grinder_kit.html
What Belts to buy?
http://www.usaknifemaker.com/abrasive-belt-basics-what-kind-should-i-buy-p-1393.html
VFD Variable Speed made simple
Step pulleys are not as cheap as you may think
Maska cast steel pulleys are good and well balanced $75 EACH here plus shaft, bearings, belt
It all adds up to about 1/2 the price of a KBAC-27D
I like direct drive with no belts using a VFD and 3 phase motor for about $200 over the price of the step pulleys with much finer control.
Yes you can get cheaper NEMA 1 VFD’s and build your own enclosure
You may find them cheaper at other retailers and on Ebay direct from china.
Wayne Coe
http://www.waynecoeartistblacksmith.com/Motors___VFDs.html
VFD-
KBAC-27D
Motor
3 phase 220v 1.5 HP motor, TEFC, frame 56 or 56C,
RPM is up to you many are happy with a 1700 RPM running at double speed.
Make sure it has a footed base for the KMG and NWG, or a C flange face mount for Bader, Bee, Wilton and GIB styles.
I get them on ebay, even with paying $80 for shipping to Canada I save $$$ on a used motor.
The 1.5 HP combination is the most common, as reported by Rob Frink
It allows you to plug into any 110vac, 15 amp outlet.
A 2 HP motor requires a 220vac input.
There are cheaper VFD units like the TECO, but the only VFD I have found that will run a 1.5 HP motor on a 110v 15 amp input is the KBAC27D
It is NEMA4, sealed from metal dust that can burnout the unit.
It has good community and company support, manuals, hook-up diagrams, photos and settings on Rob Frink’s website.
I like the fact that I can buy it from a local distributor in Canada.
Travis W reports running a 2 HP on a 110v circuit, but I haven’t tried it.
Hookup is dead simple
http://www.beaumontmetalworks.com/VS-setup.html
Safety Equipment
Protect your -Eyes, Ears, Fingers, and Lungs – remove jewellery and use safety gear.
Respirators
Chronic lung disease and cancer really suck the joy out of life.
Goggle "Ed Caffrey lung cancer"
Wearing a mask on the top of your head doesn't count.
The minimum I would consider are silicone half masks with a P100 Filter
3M 7500
http://multimedia.3m.com/mws/mediaw...Ox_Uev7qe17zHvTSevTSeSSSSSS--&fn=CH7500FP.pdf
and North 7700
http://www.amazon.com/North-Safety-770030L-Silicone-Respirator/dp/B002C08YCW
http://www.amazon.com/North-7580P100-P100-Particulate-Cartridge/dp/B000UH6PSE/ref=pd_bxgy_hi_img_b.
Use a VOC & P100 combo cartridge for protection against acetone and solvents.
Prefilters can snap over the main filter for longer life.
There are 3 sizes, buy one in person at a safety supplier and get it fitted.
For beards, pick one of these
3M PAPR
Resp-O-Rator
3m Breathe Easy
Trend Airshield Pro
Air Cap II
Searching
This Google page searches BF and works well.
http://www.google.com/cse/home?cx=011197018607028182644:qfobr3dlcra
Can I get rich making knives ?
http://www.bladeforums.com/forums/s...knife-making-worth-it?p=11980504#post11980504
V31 Nov 1, 2013
Darrin Sander is no longer HT'ing blades.
http://www.bladeforums.com/forums/showthread.php/1074496-I-m-no-longer-heat-treating-blades
If your 4x36 is anything like mine it'll be great for working on handles, but will suck for metal work. Even if you got a really good one, I haven't seen many belts that are suitable for steel grinding. I believe I saw some Blaze belts, but that's about it.
Depending on what your budget is I'd start looking at grinders that are recommended for new makers.
Yes, I was referring to thickness. Good choice going with 1/8". You can go with 1/4" later, but you very well may decide that 5/32 is plenty. Doesn't matter for now. Just keep reading. ;)
A 4x36 is a really AWFUL knife grinder. 1x30 sucks too, but it sucks slightly less. The 4x36 will bog down every time you put the metal on it. It is slow, weak and ineffective. If you are really on a low budge, buy files... good ones and a good variety of them. They work and you'll learn the basics of good knifemaking. The only thing you'll learn with a 4x36 is frustration. Is that what you want to learn?
As for being set on 1/4" stock, you aren't listening to the advice people are offering. Thin wins... thick sucks. It's not about being a newb... newbs think they want something thick. That's wrong headed. You want something that will have nice bevels leading to a sharp edge. You won't get that with thick stock. What you will get is a lot of work that ends up as a dull blade. Is that what you want? If so carry on.
Seriously, slow down. Read the stickies. You'll save yourself a LOT of time, money and frustration. And you might even end up with a nice knife.
Good luck.
1/4 inch may look "thin" on a ruler but in person when you have to take metal from 1/4" to it's final cutting surface, it's really thick!!! 1/8" is a great starting point!
Wow thats a lot of info thanks!
I got a grizzly combo sander:
http://www.grizzly.com/products/Combo-Sander-4-x-36-Belt-6-Disc/G0547
I would have loved to go for a 2x72 but it was just out of my price range and to big for the space I have right now. I would love to get one eventually...
I also got a number of belts for it going from 50-400 grit.
I'd cancel that order and look for a used Craftsman. The Grizz is basically the same as mine and it will truly suck for metal.
Save, buy a used 2x48 or just buy a good brand 1x30. I'd go with the 2". Hell, even the HF grinder will be far better and it'll leave enough for some decent belts. If you do go with the little HF I'd plan on making small knives only.
Guys, he's starting with 1/8". The rest will fall into place. ;)
I am gonna start with the 1/8" to practice on and work up to the 1/4" stock after i get some experience under my belt. As far as the belt sander I cant pick up a different one...I do however have access to a disk sander. Would that be more beneficial?
So it looks like I can get a hold of either a 1x30 or possibly a 2x42 belt sander... I will try for the 2x42 if its in good condition or ill get the 1x30 if nothing else...
