Desert Ironwood ATS34 Hunter
Feedback: +14 / =0 / -0
This is my signature drop point hunter that I have been making for several years with a highly polished finish. Made side by side with the one previously sold. There is a small flaw (see last picture) and I had a hard time deciding what to do with this knife, I decided to sell it at a discount so someone could enjoy a great knife. I was making a two pin version but everyone went wild over the six pin giving it a unique look that works well with dark wood. The gentle curve makes this a great cutting knife for most applications. The knife is professionaly heat treated to give optimum performance. The handle is desert ironwood which is a very dense strong wood with a finish mixture of shellac and carnuba wax which is hot buffed (to melt on) with a high speed buffer. The sheath is hand made with a nice barbed wire pattern, treated with neets foot oil with an antique brown stain. Razor Sharpened at about 15 degrees on each side with a convex edge to give good cutting performance with good edge retention and easy touch up with Spiderco or other fixed angle sharpener.
Steel 1/8 ATS 34 heat treat by Paul Bos
Blade 4.25" Overall 8.25"
Handle Desert Iron wood (aged about 2 years)
brass pins and thong hole
Part of my pre christmat clear out, see my web site for christmas folders.
Price Sold to the man with a Mint Julep in his hand
Another quick one, these are great knives and the Paul Bos heat treat gives you the best possible performance, paypal is prandall_2000@yahoo..
thanks
OK, so you bumped the knife into the grinder and put a divot in the top; that is still a great working knife and what a bargain. Or, you could get out your dremel tool with a carbide bit and put some file work on the top and get full price (or a little more for the embellishments).
I second what GL Drew said. I have used file pattern in the past to cover up a grinder bump.
That was my first thought, It is hardend throughout but I can use a diamond bit and some sand paper. I had the blade covered and did not see the nick until the handle was polished. wow was I disappointed.
Great design for an EDC, very usable :)
:thumbup: I like that it has no frills, just a solid working knife ;)
