I'm a noob, what's a choil?
I'll avoid the obvious and try to make a knife that somebody else may actually want, while still making sure to use my least favorite features:
Blade:
- Thick and heavy
- Over four inches long
- Some sort of complex and pointless combination of grinds and shapes, recurved for sure, maybe transition from convex to hollow with a tanto point for no reason or something fancy
- A gaudy finish like tiger stripes or digital barbed wire or something else that is supposed to look badass
- A big, pointy, single sided thumb stud
- A super thick edge
- Some holes in front of the thumb stud that descend in size
- Some variety of high hardness stainless that is easy to chip, hard to sharpen and rusts easily, maybe CPM-440V
Handle:
- Aluminum
- Some ridiculous multi-colored hard anodizing pattern over some CNC texturing (Think the original production Offset)
- A wide handle shape with some exaggerated "ergonomics" that only fit one in five people's hand correctly
- The handle swoops upward before the blade to make sure you have a nice, uncomfortable hump dictating where you are allowed to put your thumb when trying to rest your thumb on the spine of the handle in different grips
- Palm swells and a flared butt end to add width and clunkiness
- Thin liner lock (liners are jeweled and anodized)
Pocket Clip:
- Huge and shiny
- Some lame, stylized shape with lots of sharp points and flares
- Holes in it to add gaudiness
- Make it extra tight with a good in and a half or more of the knife sticking out
- Bend it in huge angles with sharp edges so that it sticks out at least a quarter inch from the handle scale, ensuring that you can't hold it comfortably at all
- Finally, make the tip of the clip pointy so as to damage anything you rub up against as much as possible
Features:
- Assisted opening with a big ass flipper. I want this baby to fill my entire front pocket up and absolutely mangle my hand when I try to shove it in there with the knife
The Wabbashock
MSRP - 299.95 (It's really expensive to make something this perplexingly useless)
Also available in all rainbow anodized finish!
Plain or combo edge!
Get explosion bonded Ti blade for an additional $600! Super high tech, super useless!
The sad thing is that I see expensive, high quality production and mid-tech folders that incorporate an alarming amount of the things I've described, and people seem to love them. Mad world.
I especially like this one. the "klaww"
"inspired by hell itself. Pull the lever in the handle and two faux damascus blades spring out (see picture 2). This is not as easy as it sounds- a good deal of force is required to get them deployed. When you let go they swing back into place with bone crunching power (well, pretty much). Rubber grip handle. Terror inducing spikes (mounted on either side of the handle) included! "
I especially like to absolute uselessness of this blade and the fact that it has "terror inducing spikes"
:barf:
"...and a compass in the stock and this thing which tells time..."you forgot the compass built into the grip.
