- Mar 8, 2008
I'd want the tang to be heat treated, too, so it doesn't bend.
A properly shaped tang will not bend in the annealed state for a pushing tool like this.
In prototyping, sure--DIY works fine. If entering into any sort of production capacity then the economy of scale will kick in, but even in small batches it shouldn't be prohibitively expensive. I got a dozen blades heat treated when I was putting my Baryonyx Machete design through the prototype phase and Peters' Heat Treat was able to do up to 20lbs of steel for $80, so only $4 per pound. That included cryo treatment and straightening as necessary after heat treatment. You'd be able to get a boatload of those little guys done up at that rate. Granted, this was back in 2010 so things may have changed, but my point is that it was pretty affordable even when I was only getting a small batch done.
Looks like a good tool.
Contact knifemaker Delbert Ealy for the cheapest heat treatment around. You can do a google search for Ealy Knives and it will come up since we are not allowed to post up links to non member sites. I have had him heat treat a bunch of my own handmade blades and he has only charged me $5.00 per blade plus the shipping cost which is usually around 7 or 8 dollars. Tell him the steel type and the hardness you are looking to achieve when you send him the blades and he will usually get the blades back to you within 30 days or less. The last batch of 3 or 4 blades I sent him was about a year ago so make sure you touch base with him in case his charges have gone up or if he is still providing that service. I am very happy with how all of mine have turned out and I have sent him some that were "mystery" steel and they still turned out pretty decent. He is also a very nice person to deal with.
why not add a folding "pedal" to allow the user to push with a foot? it would be on a hinge and normally lie up against the black ferrule, but could swing down to be used.
European shovels commonly lack a step on them and instead use one of these clamp-on ones.
That's a neat tool. I see that the Indiegogo ad says that the steel is heated to 1,100 degrees F before the quench during heat treatment, which sounds too low; might want to double-check that.
