- Mar 25, 2014
O.K., Bawanna. I'm done experimenting. What do you think of this? Only had some poisonous scrap SOFT wood to try it on, so the burning turned out fuzzy. The soft wood gets greasy under the heat and the iron wants to slide on you. Definitely not like them laser etch-a-sketches. I figure the shaft is too long for my taste, (couple three inches shorter would make for a better control touch) but if you want to try this and put it to good use, do what you see fit with it. Modify it as you will, or make a better one based off this one.
