2 for 1's are ok
Digicam PM2 mod. The scales were shaved down and polished, screw countersunk so that they fit flush. End result is a regular S30V PM that is even slimmer to carry due to the shaved down scales. (From what I read the top layer of the cloth digicam pattern came off). Was told that this has been a safe queen the last two years I've only cut paper with it and not much at that. I've been gravitating to traditionals lately.
The Natural G10 underneath the digicam pattern is a close proximation to ghost jade and I was literally fooled thinking this was a custom scale as the mod job was that good. A BF member had told me that they had seen it on the Spyderco forum and pointed out that it was a scale modification. The only way that you couldn't tell that this was all on purpose is the lanyard tube is a bit proud. The blade is centered as well.
But the end result gives you a giant PM2 blade in an even more pocketable thickness. If you really wrench the blade by the base of the handle and wiggle the tip of the blade there is very slight movement from side to side. I've had the same thing happen with similar geometry Spydercos though. It's not an issue to me but I just want to point it out. EDIT so I re-tightened the blade in the open position and it fixed nearly all of the wggle, it still drops freely though when you depress the compression lock.
Comes with original box. I ship USPS priority, box is sealed with clear packing tape and will ship Monday if this sells.
It's for sale but also for trade 2 for 1's are ok. Also looking for a 7 inch tablet.
