Rufus1949
- Aug 22, 2021
May I ask if you generally find it easy to re-enter the blades?Here's another Cheburkov not totally unlike the Leader I posted recently. This one's the Hudson (Gudzon) Lightweight version, kinda like the Shiro Hati with a Ti frame lock on the back side and a fully composite slab with no liner on the show side. I had this one partially apart not too long ago to see if I could tighten down the clip (screw at right of Ti slab) as it's just a smidgen off the scale, but it's honked all the way down and clip does work well and is stable. Like most any Russian knife I've had apart, the Hudson was lubed with black, Militec-like grease, in this case packed into the backside of the bearing retainers as you can see in the dish below. I soaked them in alcohol, then used the sharpened end of one of the swabs above to dig the stuff out, repeating the process twice.
I always re-lube with W10 NanoOil, which generally makes for a great improvement in the action. In this case the knife was pretty damn good right out of the box, which is why didn't do a complete breakdown and cleaning earlier, and the improvement is hardly significant. Still nice to have it all apart and cleaned out.
