- Jul 27, 2003
Who sells precision steel disks for disk sanders?
A couple years ago folks from this forum asked me to do a run of actual precision machined disks. It was a one time run of 100 disks.
To my knowledge, they are the only true precision machined steels disks that have been made available to knifemakers, balanced alloy steel and .000" runout.
Jo will divorce me if I ever make then again.![]()
It is my understanding that the aluminum disks by Beaumont are generally pretty good.
Jo will divorce me if I ever make them again.![]()
The nielsen magnetic discs are machined surfaces. They offer a cheap disc the is non machined mild steel as well.
You have to buy the "system" of the replaceable discs and the magnetic hubs.
After it's all said and done, it's about $350.00 just for one disc.
I need to keep looking.
Was it the ringing ?
Or the time spend to balance ?
Or just using up material on hand ?
People need to realize that just because something is "machined" doesn't mean it is inherently accurate.
The problem with most of the disks available has been wobble caused by runout and balance issues which can be addressed by the order of operations and machining strategies. The OD and the working face should be cut in the same setup that the bore is cut. And that bore can't just be drilled and reamed, it really needs to be single point bored to eliminate bellmouth and drifting. A small amount of error in the bore causes a larger amount of runout at the edge of the disk. This is pretty important to some folks.
Making a 9" disk to fit a 5/8" shaft is pretty simple, but preventing runout and vibration requires some special care.
My lathe is a small (~5,000 pounds) 10 peak HP turning center without much of a gear reduction. It does okay on smaller parts and aluminum but it really isn't designed to take heavy cuts at such a large diameter and I ended up stalling the spindle several times. It didn't have enough grunt to break a chip on this disk so we got a lot of long sharp swarf that gave all three of us a lot of little cuts. And the time/income ratio was quite poor. It's a running joke that Jo will hang me if I do it again.
