What are you asking about? Is this a question about a tapered tang or distal taper to a knife blade?
However, and error in alignment between the two sides will show badly.
"Easier to do"
Tapering a tang is very easy to do.
If it is difficult it is being done incorrectly.
I will try ........I like challengesI have done blades with tapers like that, Thy are called seax. You grind the edge bevel all the way down and off the tang, no plunge cuts. I have thought about trying it on a full tang knife, kinda a plungless grind so to speak but with the tang ground at the same angle. This way could work and be elegant but would require the knife to be designed around the grind. I think doing plunge cuts and making another plunge cut for the scales to set agenst is asking for problems.
How does that help fix your problem above?
then list me in the " done incorrectly" camp... I have had issues with tapered tangs for years and each one is a mess cleaned up with elbow grease.
