Natlek I am finishing one now that I tapered exactly the way you are describing.
I have a 2x72 and a 1x42 and that's all, no surface grinder or disc sander. I don't know what equipment you have but with what I have now, I won't do it again. It was very difficult to get the tang flat to fit the scales.
To be clear though, my knife is tapered from heel to tip, and then I tapered the tang from spine to Riccaso as well.
So mine is tapered in two ways, if that makes sense.
I wouldn't recommend doing it at least not the way I did it.
I hope you're right, we'll seei think as long as your thinnest edges on the bottom and back of the tang are at least .035" it should not warp.
Looks great.
I grind a lot of knives like this. Seems to be lighter overall and I like the look.
Thanks !
What do you think about quenching this kind of knive ? Any problem , different from normal knife ? What I'm afraid is wrapping
I think Natlek has an interesting idea. By beveling entire knife blank, tang and blade, he eliminates need to fiddle with plunge. He lightens handle enough to make for better balance on shorter blades. Drilling angled holes in handle slabs is no harder than for normally tapered tang. Works on wider blades where edge is below handle. Not so good on narrow blades. With blade edge below bottom of handle, he can thin out or convex the edge without involving tang. Heel of blade will be sharp, a potential for slippery handle to cut user. Guard would help this, but the angles make fitting a guard more difficult.
Plungeless blade on a full tang knife will have a different look, a sleeker look - some people will like it, others wont.
Reduce the weight from the handle isn't always lead to better balance. Sometime you need heavy handle to make the knife feel and use great.
Both of this knife are Winkler's belt knife. The left one is skeletonized while the right wood handle has tapered tang. Everyone who has held this knife agreed that the left one just feel much better in hand because of the heavier feeling.
Depending on the degree of skeletonizing, couldn't they both be the same handle weight? Though micarta is heavier than most woods. I think the difference in balance on a knife that size is kind of neglegable. When I'm making 3-4" hunters I try to get the balance at the front of the scale, but I'm not going to sacrifice strength or handle shape to get there. I do make most of my knives of that size a bit less then a full grip, mostly because it looks right to me, and also because I haven't found the amount of grip area to be a hinderance.Reduce the weight from the handle isn't always lead to better balance. Sometime you need heavy handle to make the knife feel and use great.
