So I found a doc that explains what was probably already explained here and implemented in the doc. from Dan here BUT this one I can understand.. haha. If I make 2 zones, each 3000watts, it would go as so:
14G wire (.064) for 19.2ohms, resistance of 0.2123 ohms/ft
L = 19.2ohm / 0.2123 = 90.44 length
Surface area = PI (3.1415) x dia (0.064) x L (90.44) x length of wire in inches (12) = 218.2 square inches
Watts (3000)/ area (218.2square inches) = 13.75 watts per square inch
Current = watt/volt? = 3000/240 = 12.5 Amps
from what I could find, the surface load should be under 17.5watts per square inch? Krugerpottery has an element on their site for 240 at 24 amps, 2880watts 14G at 13W/sq. in. This seems very close and within all parameters. Only difference is I need 3/4" OD for the wire to fit in the available space.
Seems to be an actual step forward! What do you guys think?
