This would be nice ovenLength wise would mean that you would need to groove out the roof bricks so the coils and rods are in them like when they're in the walls) and they would need to be inserter in a piece at the front and lay on the back wall. Thought about it but that makes for some LONG rods in my case (38") and would need 4 of them.
I just followed @ design mostly and chamber recommendations from @Stacy E. Apelt - Bladesmith I believe for the 7 x 5. I'm probably going to build a size replica of this one when it's down but MUCH SIMPLER: one T.C. with normal PID from Auber for something with less bang (4200w 17.5 amps-ish) and to be used as a tempering oven for the long blades. Not sure if I'll go top coils again or sides. I might try the top again but less rods (2 per brick instead of 3 so 16 coils total instead of 23) and have them recessed in the top instead of completely IN the chamber.
Speaking of chamber, I've tried looking into this: can you put blades FLAT in the oven? do they HAVE to be edge up? I have about 4" and a bit of height clearance because of the coils which is fine for what I want to do but if I ever wanted to do something bigger or more curved, could I lay it down on a horizontal rack for the heat treat? I got 7' across which could fit most things outside of a buster sword. Is there a distance you want to keep from the coils with whatever you insert in them?
I see you haven't opened the passage for the end of the element yet ? Maybe both ends to go back? I mean on the longer end of element goes inside the oven like in the picture? It's somehow more elegant and safer than going from the outside ?
About tempering oven ...... If you're making it strictly just for that, I think it's better to use elements that go into kitchen ovens. They make them in different shapes, power and dimensions . It is much easier to install them and they last a long time . Their permitted temperature is around 750 degrees Celsius, which is more than enough. A fan inside is a must ...in tempering oven .
look in this thread to get idea
Building tempering Oven
Yes, the muffle is what protects the blades from direct exposure to the hot elements. The metal would replace what you had as glass.
www.bladeforums.com
