Any tube, ,round or or square, will work. It is just a shell to wrap the insulation around. Think of this project as a long thin toaster oven. Sheetmetal would be fine. Use two elements if needed to get the desired length. You could even put them on separate controllers to keep the oven evenly heated.
Ok I'm on my way to get some tile/kaowool/high temp gasket putty(glue/caulk etc). I'd rather not have to buy a controller since you are helping me out with one.
Stacy you said something earlier that I kinda missed. I think I'd rather follow some plans on youtube to build a basic grinder for these tasks rather than try and hand grind metal. what horsepower motor would you recommend for sword grinding?
Whats the longest 110 heat element you've seen out there? I dont want to do as many as natlek. Surely 2 long ones would do the task? most of the long ones i see for elements are 220 volts.
