David Martin
Moderator
- Apr 7, 2008
Obsessed with Edges
I definitely agree with you an India stone is a poor choice for sharpening these steels. In this case though the sharpening is being done with the med crystolon. The India fine is only being used for final honing. In your example you were reprofiling which those Lansky stones were unsuited. As the final polish though for those last few swipes it would've done fine.
India stones do tend to glaze over especially the fine one. It's what you get with a hard, tough, and smooth binder. They will glaze over even with 1084. A quick lapping with some 50-100 sic loose grit on a flat surface fixed that and you'll barely remove any material from it
With these steels diamond may be the way to go but I just don't like the use of or economy of diamond plates. The India stone may glaze but you can always unglaze it. You can't sharpen diamonds back up when they dull. At that point your $100 plate is a paperweight. My $30 stone still has 50 years of life left
Just one man's opinion
Eli Chaps Fair point. I will admit I can be biased sometimes about this stuff due to availability. I'm in Canada so that "cheap" $40 plate would cost me $120 after shipping and exchange rate. That's if it doesn't get customs charges which could add $40-$60 more. There is no cheap and mail order here. For less than that I could get an atoma plate at my local Lee Valley tools. Same as these newer resinoid diamond stones. Prohibitively expensive.
The tri hone kit the op is looking at is $400 here. I got lucky and paid $10 at a yard sale
I still stick with diamonds are not necessary for s30v or any steel for that matter. That doesn't mean you should not get some if you want. I have a 13k water stone that is completely useless to me and yet I have it!
So enjoy what you like but lets not push aside hard facts and evidence either
I agree with most of it, but it is interesting that you wrote that feedback is good on diamond plates and not on water stones. I think you are using feedback differently from usual when talking about sharpening on stones. In general most agree that feedback, the feel when sharpening sucks on diamond plates, it is very unpleasant. On the other hand good water stones are a pleasure to sharpen on with creamy feedback, both the feel and the sound are great benefits of quality waterstones.
Sorry if this is a little off topic but I'm considering going to diamonds but wondering if they produce usable edges at the get go?I do know they do need breaking in but if I get a stone I do like to know they are usable at the first sharpening.The ones I've dabbled with in the past have left ragged hacksaw edges even with light pressure.My oilstones have given me sharp edges from the first use. Your input would be appreciated.
For what seemed like similar impressions to yours, it took me a while to calibrate my sense for using diamond hones. For quite some time, I also had the impression edges produced were too rough coming off of them. Part of that was in initially assuming the choice of grit should approximately match what I'd been used to. But, since diamonds cut so much more deeply for a given grit, as compared to other stone types, an adjustment needs to be made for that. This means using a finer diamond grit than I would initially be inclined to choose. For example, to emulate the finish coming off something like a Fine India stone (rated ~360-grit, give or take), a finer diamond should be chosen, like a Fine DMT (600), or sometimes even an EF DMT (1200). A 325-mesh DMT (Coarse) will produce scratch patterns much, much coarser than the 360-grit Fine India. More so, on steels that aren't very wear-resistant in the first place, because diamond will cut them even more deeply at the same light pressure.
Once I figured out the touch for them, and also how each diamond grit performed, I realized it wasn't so much an issue of them needing break-in, to perform as I expected. This realization has been confirmed in subsequent new diamond hones I'd purchased, after learning the 'touch' on others I'd used for a while. At Coarse, Fine and finer grit, my DMT hones, at least, have performed well as I expected, on their first day of use.
I still feel DMT is much more consistent than other similarly rated & priced diamond hones, in the sense that they cut very cleanly from early on, and edges produced on them don't need much, if any, further refinement or cleaning up. Can't say the same for other brands I've tried, some of which leave more burring issues behind. This isn't to say others aren't pretty good as well. It's just that I keep noticing DMT has been consistently better.
Thank You for your response!I had been thinking of a DMT coarse/fine but but you now have me contemplating a fine/extra fine BUT what has kept me from that is I've heard that the extra fine is plagued with large grit contaminating the stone and causing "catches" during your stroke.Or is this overblown?
If you're close to the border you can have goods sent to a US receiving centre, go down and pick up your package, all legally.Eli Chaps Fair point. I will admit I can be biased sometimes about this stuff due to availability. I'm in Canada so that "cheap" $40 plate would cost me $120 after shipping and exchange rate. That's if it doesn't get customs charges which could add $40-$60 more. There is no cheap and mail order here. For less than that I could get an atoma plate at my local Lee Valley tools. Same as these newer resinoid diamond stones. Prohibitively expensive.
