I actually have used my MOD CQD Mk1 to break glass and it does the job just as described.
How hard did you have to hit the glass? Car or home glass?
Hi,
Doesn't matter, carbide or steel works just fine. Tempered glass is almost as brittle as regular glass. It just breaks in to small "beads" rather than larger shards that can cut or puncture you like a knife. Automatic center punches are steel and are the preferred tool.
If you must try and break glass, please wear safety glasses, long sleeved shirt or coat, and heavy gloves. Stand to the side of the window, and with a hammer type tool, give a quick, sharp blow to the bottom corner. If you are using an auto punch type tool, place it up against the bottom corner and press punch to fire it. In either case, the idea is to drop the pieces straight down and not to have them scattered all over the interior or the patient.
I have a Vic Rescue Tool, (gift from my two youngest Daughters). I carry it in my own personal jump bag. I've tested the tools and they do work. The glass saw will cut safety glass. But as was pointed out by Josh, we use a Sawz-All to cut laminated glass. It's far faster and easier. If we cut the glass, we're probably going to remove the vehicle roof also. So a Sawz-All is better.
dalee
It wasn't very hard, maybe the force you'd use to rap on a door, tap a nail in, etc. Home glass was actually harder to break than auto glass, I'll never know why, maybe adrenaline, maybe they had thick windows. Just make sure to go for the bottom corner:thumbup:
Why the bottom corner?
No ofense, But if it took the guy to Karate chops to break with sharp carbide glass breaker, he either didn't actually hit the glass on the first try with the small peice of carbide, or he was very very weak. Very weak. Like a small child.
Do you guys think a pick & pull place would let me shatter a few car windows??
a little trick for anyone needing to break a car window, using a carbide tipped rescue knife or similar.
us the carbide to first scratch an big X into the glass, then hit dead center of the X. Takes less than 5 seconds to do both. I've broken 1/2" thick safety glass this way (training)
I reckon if you hit a window hard enough with the but of a knife its gonna break.
I don't want anything long, sharp and pointy next to my patient. Me and the patient are both having a bad enough day at that point.
Personally, I think knives sold as a "Rescue Knife" are pretty silly.
dalee
