If you elect to stay with 120vac, buy a 2hp motor for the grinder. Set the VFD for 1.5hp and it will work just fine. Then if you ever do have 220vac you've already got the 2hp motor. Actually you don't have to set the CFD for 1.5hp, leave it at 2hp is just fine. The VFD doesn't have a clue what hp the motor is, only how much current is being pulled by motor. The only time that 2hp motor will pull full current is when you're REALLY leaning on it trying to bog motor down (pulling over 1.5hp of current), then the VFD will "protect" itself by shutting down on overcurrent. Do a reset and go back to grinding. The starting current surge is no load so won't be an issue.
Comments on that idea?
