Does anyone know of a good chopping knife.
I'm looking for a chopping battening and etc. I know Busse produces some but for the price is it worth it and I know esee is good but I just keep thinking its to thin for a chopper. looking for blade length 9-13 inch steel thickness 0.250-0.300
I assume we are past the common chopping tool, the axe.
The Khukuri [three syllables] (AKA, misleadingly, "kukri") is a chopping knife. It is 1/4" or more thick with a full convex grind (like a proper axe) and weight forward. The bend in the blade pulls the "work" into the blade when chopping in the same fashion that a properly set-up axe does. Traditionally, it is deferentially hardened so the unhardened spine can absorb the shock of chopping impacts. Many tools called khukuris by large U.S. companies are not.
The bolo, parang or golok chop pretty well but are a compromise chopping/slashing tool.
Other large, sturdy knives can shop - typically less well than tools optimized to chop.
Batoning can be done with any reasonable sturdy knife as it is less stressful than chopping, but sturdier knife is more likely to survive excessive force (Some just smash thre H### out of them.) or poor technique. A longer blade allows longer cuts when batoning.
Yes, BK9..
Sometimes that thinness is what gives it "the edge"
On an extreme budget, I just the kabar kukri machete, not a real khuk ; and I love the the large heavy bowie, but kits more "knife" than the bk9, the 9 is More "tool"
Take a look at the Browning Crowell/Barker Competition knife. It meets your requirements with a 10" blade that is .250" thick, flat ground with a convex edge, and made from 1085 carbon steel. Black micarta handles, with a tapered tang. Before I had a spinal cord stroke, I used mine to do some chopping of fallen trees and it did an excellent job.
+1 for the BK9 or if you want more of a budget chopper the kershaw camp 14 is a hell of a chopper for $40.
Swamp Rat and SYKCO make some 9-11" blades that are .25" thick. The BK9 is thinner, but still a terrific chopper--it surpasses my $20 hatchet if that means anything...
Ontario SP 8 -- http://www2.knifecenter.com/item/ON...ival-10-inch-blade-cordura-and-leather-sheath
Condor Heavy Duty Kukri -- http://www2.knifecenter.com/item/CN...n-Steel-Blade-Hardwood-Handles-Leather-Sheath (This is the thickest at 5/16".)
Ontario Kukri -- http://www2.knifecenter.com/item/ON6420/ontario-kukri-machete-blade-cordura-sheath
Ontario SP 10 Marine Raider Bowie -- http://www2.knifecenter.com/item/ON...-marine-raider-fixed-9-34-blade-kraton-handle
Ontario Gen II SP 50 -- http://www2.knifecenter.com/item/ON...ife-8815-inch-Flat-Ground-Blade-Kraton-Handle
Ontario Gen II SP 53 -- http://www2.knifecenter.com/item/ON...fe-9436-inch-Saber-Ground-Blade-Kraton-Handle
Ka Bar Combat Kukri -- http://www2.knifecenter.com/item/KA...-Blade-Black-Kraton-G-Handle-Polyester-Sheath
Ka Bar Large Heavy Bowie -- http://www2.knifecenter.com/item/KA...Blade-Kraton-G-Handles-Leather-Cordura-Sheath
Ka Bar Cutlass Machete -- http://www2.knifecenter.com/item/KA...-Blade-Kraton-G-Handle-Leather-Cordura-Sheath
Becker BK9 -- http://www2.knifecenter.com/item/KA...-Combat-Bowie-Knife-9-inch-Carbon-Steel-Blade
Cold Steel Trailmaster -- http://www2.knifecenter.com/item/CS...-trail-master-o-1-steel-blade-kray-ex-handles
Cold Steel Marauder -- http://www2.knifecenter.com/item/CS39LSWB/Cold-Steel-39LSWB-Marauder
Brusletto Villmann -- http://www2.knifecenter.com/item/BR...12C27-Blade-Birch-Handle-Brown-Leather-Sheath
Cold Steel Gurkha Kukri -- http://www2.knifecenter.com/item/CS...-1-steel-blade-kraton-handle-secure-ex-sheath
Ka Bar Big Brother -- http://www2.knifecenter.com/item/KA...ed-Blade-Leather-Handles-Brown-Leather-Sheath
Ontario Randall RTAK 2 -- http://www2.knifecenter.com/item/ONRTAK2/Ontario-Randall-RTAK-2-Knife-Micarta-Handle-1025-inch-Blade
Ontario RD9 -- http://www.knifeworks.com/ontariord9blackmicartahandleblackbladecomboedge-1.aspx
You need a BK9. Period.
However, if you want two choppers, then also look at the Scrapyard 911 and 1111, Swamp Rat, ESEE Junglas, several from Ontario, and the BK4 from Becker.
If you could talk Tim Olt into making you one of these, it would satisfy your quest for a chopper. Ten inches of .28 thick A2 steel!
I have an esee junglas and though not 1/4" thick, it chops very well and wouldn't trade it for much. fantastic knife and good sheath too
Really depends on price range, but for my money, my two favorite choppers are the Scrapyard 1311 and the Busse Killa zilla( kukri)
The Scrapyard 1111(can buy from website) or the 1311(if you can find one) are well worth the price IMHO. Get a Mistress if you can :)
im content with my Junglas and the BK9. the only things ive changed is G10 on the ESEE, micarta on the Becker as well as a kydex sheath to replace the factory one.
