Does anyone prefer stainless steel over cv steel?
Most of my blades are of buck's 420hc and case's cv. In my non-expert experience they are very similar (or at least close enough), especially in edge retention and ease of sharpening. With similar stainless and non-stainless steels I give a slight edge to non-stainless, just because. It's a knife, the cutting ability is more important to me.
Over the years I have had two knives in Case's SS and several in their CV. I prefer the CV over the stainless, in my opinion, the SS doesn't sharpen as well neither retains an edge as well.
If Buck is high carbon what makes it stainless? Thanks
Bob
I believe the term "high carbon" means the alloy has at least 0.50% carbon. More than 12% chromium makes an alloy stainless.
420J2, a low carbon stainless steel, has only 0.15% carbon, limiting it's hardness after heat treatment to only the low 50s HRc.
Buck's 420HC usually runs around 57-58 HRc, with it's excellent Bos heat treatment.
I have good luck with Buck 301 at work with minimal maintenance.
"Stainless Steel" is steel with at least a certain % of Chromium. The lower limit of Chromium content for a "stainless steel" varies a bit depending on which authority you cite. Some say "12%". Some say "greater than 10%". If all other constituent elements are held the same, then the more Chromium in the alloy, the more stainless it is.
Buck uses 420HC, which contains 12-14% Chromium according to the ASTM specification for 420 alloys, putting it well into the "stainless steel" category.
