- Mar 8, 2008
The confusion over geometry and sharpness seems to be thinking that they are separate. Sharpness measurements are done of cutting force required, which is affected by geometry, and the tests reflect this.
The closest I can think that this discussion has been revolving around is the level of refinement at the meeting of the two edge bevels. This is also a question of geometry, as what is measured is the radius of the curve joining the two sides. As this is less than a micron for highly refined edges, this has little to do with cutting. That is why geometry is such a critical component of sharpness, the blade needs to penetrate the media to some depth, and I think that we have always needed that depth to be greater than a millionth of a meter. The real challenges in measuring sharpness are the differences in elastic ranges and fracture mechanics of the various materials we cut.
Check up on ISO 8442.5 and related discussions for measuring sharpness in knives, scalpels, needles, etc. There are several papers on sharpness tests outside of CATRA REST/REDS, such as non-destructive tests in gel and fiberglass test media.
Personally I consider sharpness to mean the degree of refinement of the meeting of the two sides of the blade, while the general term geometry is used to describe everything behind the point making initial contact with the cutting medium. So sharpness is an extension of geometry in the same way that a square is a rectangle. The edge is the face that experiences the most significant degree of wear during cutting, and is the aspect of geometry that we, as users, maintain. So it is part of the geometry of the blade, yes, but it's also a little more distinct than that. It represents a specific and localized aspect of the blade geometry.
