or wrecking bars.That's why they make Medfords: so you don't have to use your GECs for prying. (*_*)
Blade delete for sure. Wouldn’t bother GEC with my stupidity.or wrecking bars.
rdrogers Time for a pen blade delete? Or is there a greater than snowball's chance in h€|| that GEC will sell you a replacement blade?
MaybeBlade delete for sure. Wouldn’t bother GEC with my stupidity.
Maybeglennbad or one of the other modders here has a replacement blade left over from someone else's blade delete?
Oh no!! I love those little two blade jack 14’s. Quick and crude way for a blade delete…
Caplifting is a form of prying so No.Is there enough left for a cap lifter?
Good chance to turn lemons into lemonade?!
No.Don't pry? Not even a little bit?
I don't know what else they could be good for since they seem like a better pry bar than a knife, but they also seem like a worse pry bar than an actual pry barThat's why they make Medfords: so you don't have to use your GECs for prying. (*_*)
Oof, Hard to judge size of these guys sometimes. I have a little 14 that looks like this one so I just assumed. Bummer it happened!
I would say that 50% of the knives I carve with will eventually loose a tip. Notice the warncliff is not quite as pointy as it came from the factory. I have become fairly proficient at correcting the issue. Now the ops issue is a whole nother level.Dont leave us hanging...what did you pry?
No.
And by the looks of that blade it was more than a little bit of prying ...
Heres the reason for my Chronic Pryanoia ..View attachment 1843167
This #79 Workhorse Whittler...Mammoth scales is the 2nd most
expensive knife I own...
I stuck it straight into a piece of soft weathered half rotten log for a photo...when pulled it out the tip had snapped off...OK I may have levered it slightly but no way should it have broken...ground too thin and thats why I say Not SurPrysing.Dont Pry.
